removing inside door handle
Old Apr 21, 2014 | 07:08 PM
jerryst's Avatar
jerryst
I started to install my Altman door latch system on my 55 f100. I can not get the inside door handle off. I have sprayed pb blaster and tried prying it off. Any ideas? Also do you have to remove the inside handle? Thanks for any information.
jerry
Old Apr 21, 2014 | 07:16 PM
FortyNiner's Avatar
FortyNiner
The inside handle has a spring loaded ring - push it away from the door - there is a pin holding the handle in place. Push the pin out and the handle can be removed. Kudos to Ilya for this knowledge.
Old Apr 21, 2014 | 08:06 PM
topmoo's Avatar
topmoo
You don't have to take it off, it connects to the arm on the Altman latch. I took mine off anyway just to inspect and make sure it was not too worn. The pin comes out with an 1/8" punch and hammer while holding the black spring loaded spacer ring away from the bottom of the handle.
Old Apr 22, 2014 | 03:44 PM
Okiedokie's Avatar
Okiedokie
I think you have the horseshoe clip on your 55. Not fun to deal with. Mid Fifties has a tool although you can manipulate it off with small screwdrivers/picks. Been too long since I did that to be more specific. I use the tool now that I have one.
Old Apr 22, 2014 | 04:26 PM
r_reed's Avatar
r_reed
if you indeed have the horseshoe clip, i bought one years ago at napa. maybe they still have them, they are great for removing and installing the clips.
looks like they have them: http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
Old Apr 23, 2014 | 12:49 AM
jerryst's Avatar
jerryst
Thanks for all the input. I got the door handle off today. It had a clip inside the handle. After I took it off I realized I could have left it on. But oh well. On to installing Altman latch system. Tomorrow I draw the outline and hopefully start cutting.
Jerry
Old Apr 23, 2014 | 05:15 PM
53OlderThanMe's Avatar
53OlderThanMe
Jerry
Take some pictures and post for us, thinking about this in the future. Tired of the door slam knocking my window rollers off.
Old Apr 23, 2014 | 10:17 PM
Olweldinrig's Avatar
Olweldinrig
For horse clips a banana knife is what I use,works well.When I was a kid I had a fork with bent fingers and two middle ones removed.
Old Apr 23, 2014 | 10:26 PM
Project-55's Avatar
Project-55
Dang it, You mean that my method of using the air saw is wrong??
str8patina
Apr 9, 2017 04:15 PM
fordguy55
Jul 9, 2010 09:54 AM
40hotrod
1947 and Older Ford Trucks
Aug 3, 2005 01:46 PM
exlmtd
Jun 10, 2004 07:52 PM
Fordtrucktexan
1997 - 2003 F150
Jan 27, 2003 08:20 AM
