Hum after shutdown.
Old Apr 20, 2014 | 06:04 PM
F350Jay's Avatar
F350Jay
Hum after shutdown.
My 2011 6.7 just started making a hum noise after shutdown. I've read that it might be the wastegate solenoid. Does anyone know if there's a TSB for this. My truck is tuned so hopefully my dealer will be tuner friendly. If not it can't be that expensive to buy the part.
Old Apr 20, 2014 | 07:57 PM
PlayersZ28's Avatar
PlayersZ28
Mine will make a humming noise followed by what almost sounds like a burp and then quiet. As far as I know this is the waste gate solenoid
Old Apr 20, 2014 | 11:01 PM
hschiro's Avatar
hschiro
I posted about this awhile back and everyone seems to believe it is a solenoid. Mine has been doing it for close to a year now. Runs for 30 seconds or so after shutting engine off. I have also noticed it during the engine running fyi. so far no problems to speak of with it however.
Old Apr 21, 2014 | 01:01 AM
TRENT310's Avatar
TRENT310
That was one of the noises that disappeared after I removed my EGR cooler. Just wasn't a thing ever again. Whether it's directly related or just a side effect I don't know.
Old Apr 21, 2014 | 03:22 AM
Marauder92V's Avatar
Marauder92V
I had the hum as well. I don't know if it was under a TSB, but I do believe it was the waste gate controller.
Old Apr 21, 2014 | 05:16 AM
senix's Avatar
senix
TSB for the wastegate noise:
File Type: doc
Old Apr 21, 2014 | 05:37 AM
ruschejj's Avatar
ruschejj
Waste gate solenoid.
To diagnose, press the brake pedal after you have shut down and the noise starts, if the sound stops it's the waste gate solenoid.
No service action is required or even suggested, they want us all to have to hear this.
As far as anyone has ever said, there's nothing wrong with it, nothing is defective or broken or wearing out. It just happens. Mines been doing it for at least 40,000 miles now.
Old Apr 21, 2014 | 10:14 PM
F350Jay's Avatar
F350Jay
Update.
I drove to Ford today and talked to the diesel mechanic. He listened to my truck hum after I shut it off. He agreed it was the waste gate control valve. I showed him the TSB (thanks Senix) and he was surprised that TSB had been issued. He told me he's seen the problem and that Ford did not recommend a fix. The dealer had the part in stock and will be fixing it next week. On a side note-I noticed a 6.7 getting a new engine. I asked about it and was told that there's been an issue with the motor seizing up. I've never heard that. He said that there's also been an issue with the glow plug dropping inside the motor and causing major damage. I was surprised to hear this. Especially since my truck is tuned.
Old Apr 22, 2014 | 05:08 AM
senix's Avatar
senix
there have been some valves dropped as well. Early on 2011's, mostly chassis models.
Not a common problem but enough that they did a fix for the valves.
Old Apr 22, 2014 | 09:30 AM
Rutcutter's Avatar
Rutcutter
Hey Senix could you post a copy of that TSB as I couldn't get it to open..
Old Apr 22, 2014 | 09:55 AM
jermort's Avatar
jermort
more info
You might want to read my OP. Some good info including pictures and sound recordings for comparison. Mine was replaced under warranty, many since then have been refused. Here's the part from my original post:
https://www.ford-trucks.com/forums/1...l#post10309654
Make sure that your dealer is going to follow the TSB and you don't get caught in paying! I understand that Ford has issued an advisory telling dealerships to not replace the part. Ford now considers the noise 'normal'! D'oh!
Good luck, that damn noise is certainly annoying!
jammer
Old Apr 22, 2014 | 11:07 AM
senix's Avatar
senix
FulltextTSBs <o></o>
TechnicalService Bulletins<o></o>
TSB Main Page :: Year 2012:: Model F-250:: TSB 13-10-7<o></o>
<table width="96%" class="MsoNormalTable" style="border: 2.25pt outset currentColor; width: 96%; mso-cellspacing: 0in; mso-yfti-tbllook: 1184; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt;" border="1" cellspacing="0" cellpadding="0"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="background: blue; padding: 2.25pt; border: rgb(0, 0, 0);" colspan="2"></td></tr><tr style="mso-yfti-irow: 1;"><td width="25%" style="background: white; padding: 2.25pt; border: rgb(0, 0, 0); width: 25%;">
TSB
13-10-7<o></o>
</td><td width="65%" style="background: white; padding: 2.25pt; border: rgb(0, 0, 0); width: 65%;">
  • 6.7L DIESEL – BUZZING NOISE UNDER HOOD<o></o>
</td></tr><tr style="mso-yfti-irow: 2; mso-yfti-lastrow: yes;"><td style="background: blue; padding: 2.25pt; border: rgb(0, 0, 0);" colspan="2">[************]Publication Date: October 3, 2013[/COLOR]<o></o>
</td></tr></tbody></table>
<o> </o>
<table class="MsoNormalTable" style="mso-cellspacing: 1.5pt; mso-yfti-tbllook: 1184;" border="0" cellpadding="0"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes;"><td width="230" style="padding: 0.75pt; border: rgb(0, 0, 0); width: 172.5pt; background-color: transparent;">FORD:<o></o>
</td><td style="padding: 0.75pt; border: rgb(0, 0, 0); background-color: transparent;">2011-2012 F-250, F-350, F-450<o></o>
ISSUE:<o></o>
Some2011-2012 F-Super Duty 250-450 pickup trucks equipped with a 6.7L diesel enginemay exhibit a buzzing noise from under the hood while the engine is runningand/or for up to thirty (30) seconds after the engine is shut off. This concernmay be due to the wastegate control valve vacuum harness causing the wastegatecontrol valve to resonate. <o></o>
ACTION:<o></o>
Followthe Service Procedure Steps to correct the condition. <o></o>
SERVICE PROCEDURE<o></o>
  1. Does the wastegate control valve emit a buzzing noise while the engine is running and/or for up to thirty (30) seconds after engine is shut off?<o></o>
    1. No – this article does not apply. <o></o>
    2. Yes – proceed to Step 2.<o></o>
  2. With the buzzing noise present, disconnect the vacuum hoses from the wastegate control valve. Does the buzzing noise stop?<o></o>
    1. No – this article does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics.<o></o>
    2. Yes – proceed to Step 3.<o></o>
  3. Replace the wastegate control valve vacuum harness.<o></o>
    1. Remove the throttle body. Refer to Workshop Manual (WSM), Section 303-12.<o></o>
    2. Remove the air cleaner outlet pipe. Refer to WSM 303-12.<o></o>
    3. Remove three wire harness retainers and position aside engine wire harness. (Figures 1 and 2)
      <!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="Picture_x0020_1" o:spid="_x0000_i1026" type="#_x0000_t75" alt="https://www.ford-trucks.com/wp-content/themes/fordtrucks/images/fulltext/2354/tb10461a.jpg" style='width:240pt;height:156pt;visibility:visible '> <v:imagedata src="file:///C:\Users\ebgea11\AppData\Local\Temp\1\msohtmlclip1 \01\clip_image001.jpg" o:title="tb10461a"/> </v:shape><![endif]--><!--[if !vml]-->[IMG]file:///C:/Users/ebgea11/AppData/Local/Temp/1/msohtmlclip1/01/clip_image001.jpg[/IMG]<!--[endif]-->
      Figure 1 – Article 13-10-7
      <!--[if mso & !supportInlineShapes & supportFields]>*SHAPE* \* MERGEFORMAT <![endif]--><!--[if gte vml 1]><v:rect id="AutoShape_x0020_2" o:spid="_x0000_s1026" alt="https://www.ford-trucks.com/wp-content/themes/fordtrucks/images/fulltext/2361/tb10462a.jpg" style='width:24pt;height:24pt;visibility:visible; mso-position-horizontal-relative:char;mso-position-vertical-relative:line' o:gfxdata="UEsDBBQABgAIAAAAIQC2gziS/gAAAOEBAAATAAAAW0NvbnRlbnRfVHlwZXNdLnhtbJSRQU7DMBB F90jcwfIWJU67QAgl6YK0S0CoHGBkTxKLZGx5TGhvj5O2G0SRW Noz/78nu9wcxkFMGNg6quQqL6RA0s5Y6ir5vt9lD1JwBDIwOMJKHpH lpr69KfdHjyxSmriSfYz+USnWPY7AufNIadK6MEJMx9ApD/oDOlTrorhX2lFEilmcO2RdNtjC5xDF9pCuTyYBB5bi6bQ4syoJ 3g9WQ0ymaiLzg5KdCXlKLjvcW893SUOqXwnz5DrgnHtJTxOsQf EKIT7DmDSUCaxw7Rqn8787ZsmRM9e2VmPeBN4uqYvTtW7jvijg 9N/yJsXecLq0q+WD6m8AAAD//wMAUEsDBBQABgAIAAAAIQA4/SH/1gAAAJQBAAALAAAAX3JlbHMvLnJlbHOkkMFqwzAMhu+DvYPRfX GawxijTi+j0GvpHsDYimMaW0Yy2fr2M4PBMnrbUb/Q94l/f/hMi1qRJVI2sOt6UJgd+ZiDgffL8ekFlFSbvV0oo4EbChzGx4f9 GRdb25HMsYhqlCwG5lrLq9biZkxWOiqY22YiTra2kYMu1l1tQD 30/bPm3wwYN0x18gb45AdQl1tp5j/sFB2T0FQ7R0nTNEV3j6o9feQzro1iOWA14Fm+Q8a1a8+Bvu/d/dMb2JY5uiPbhG/ktn4cqGU/er3pcvwCAAD//wMAUEsDBBQABgAIAAAAIQCwpwTE8QIAABkGAAAOAAAAZHJzL2U yb0RvYy54bWysVNtu2zAMfR+wfxD07vhS5WKjTtHG8TCg2wp0+ wDFlm1ttuRJSpxu2L+PkpM0afe0zQ+CRMqHPOQRr2/2XYt2TGkuRYrDSYARE4UsuahT/OVz7i0w0oaKkrZSsBQ/MY1vlm/fXA99wiLZyLZkCgGI0MnQp7gxpk98XxcN66ieyJ4JcFZSddTAU dV+qegA6F3rR0Ew8wepyl7JgmkN1mx04qXDrypWmE9VpZlBbYo hN+NW5daNXf3lNU1qRfuGF4c06F9k0VEuIOgJKqOGoq3ir6A6X iipZWUmhex8WVW8YI4DsAmDF2weG9ozxwWKo/tTmfT/gy0+7h4U4iX0DiNBO2jR7dZIFxlFGJVMF1CuQ1uGYZhAL0rPqG 3xTTsOQ+8VUhgmjG+gaUz79sZ4wecdra1l27aG7Y0fXc1C32zC gMwiOvna17YBQ68TyOOxf1C2hLq/lwCOhFw1VNTsVvfQxjHBo0kpOTSMllCJ0EL4Fxj2oAENbYYPsg RKFCi59uwr1dkYUHi0dyp4OqkA8kMFGK8CsghAKwW4DnsbgSbH n3ulzTsmO2Q3KVaQnQOnu3ttxqvHKzaWkDlvW7DTpBUXBsAcLR AafrU+m4TTzc84iNeL9YJ4JJqtPRJkmXebr4g3y8P5NLvKVqss/GXjhiRpeFkyYcMcNRySU9OOb+mP0ju8plF9JxVr2fLSwtmUtKo 3q1ahHYU3lLvPlRw8z9f8yzRcvYDLC0phRIK7KPby2WLukZxMv XgeLLwgjO/iWUBikuWXlO65YP9OCQ0pjqfR1HXpLOkX3AL3veZGk44bmFIt7 1IM0oDPXqKJVeBalG5vKG/H/VkpbPrPpYB2Hxvt9GolOqp/I8snkKuSICdQHsxT2DRS/cBogNmUYv19SxXDqH0vQPJxSIgdZu5ApvMIDurcszn3UFEAVIo NRuN2ZcYBuO0VrxuIFLrCCGlffsWdhO0TGrM6PC6YP47JYVbaA Xd+dreeJ/ryNwAAAP//AwBQSwMEFAAGAAgAAAAhAEyg6SzYAAAAAwEAAA8AAABkcnMvZG 93bnJldi54bWxMj0FLw0AQhe+C/2EZwYvYjSJSYjZFCmIRoZhqz9PsmASzs2l2m8R/36ke9DLD4w1vvpctJteqgfrQeDZwM0tAEZfeNlwZeN88Xc9BhY hssfVMBr4pwCI/P8swtX7kNxqKWCkJ4ZCigTrGLtU6lDU5DDPfEYv36XuHUWRfad vjKOGu1bdJcq8dNiwfauxoWVP5VRycgbFcD9vN67NeX21Xnver/bL4eDHm8mJ6fAAVaYp/x3DCF3TIhWnnD2yDag1Ikfgzxbubi9r9bp1n+j97fgQAAP//AwBQSwECLQAUAAYACAAAACEAtoM4kv4AAADhAQAAEwAAAAAAAA AAAAAAAAAAAAAAW0NvbnRlbnRfVHlwZXNdLnhtbFBLAQItABQA BgAIAAAAIQA4/SH/1gAAAJQBAAALAAAAAAAAAAAAAAAAAC8BAABfcmVscy8ucmVsc1 BLAQItABQABgAIAAAAIQCwpwTE8QIAABkGAAAOAAAAAAAAAAAA AAAAAC4CAABkcnMvZTJvRG9jLnhtbFBLAQItABQABgAIAAAAIQ BMoOks2AAAAAMBAAAPAAAAAAAAAAAAAAAAAEsFAABkcnMvZG93 bnJldi54bWxQSwUGAAAAAAQABADzAAAAUAYAAAAA" filled="f" stroked="f"> <o:lock v:ext="edit" aspectratio="t"/> <w:wrap type="none"/> <w:anchorlock/> </v:rect><![endif]--><!--[if mso & !supportInlineShapes & supportFields]><v:shape id="_x0000_i1025" type="#_x0000_t75" style='width:24pt;height:24pt'> <v:imagedata croptop="-65520f" cropbottom="65520f"/> </v:shape><![endif]-->
      Figure 2 – Article 13-10-7<o></o>
    4. Disconnect vacuum harness and remove.<o></o>
    5. Reverse procedure for installation.<o></o>
<o> </o>
<table class="MsoNormalTable" style="mso-cellspacing: 0in; mso-yfti-tbllook: 1184; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt;" border="1" cellspacing="0" cellpadding="0"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">
PART NUMBER<o></o>
</td><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">
PART NAME<o></o>
</td></tr><tr style="mso-yfti-irow: 1; mso-yfti-lastrow: yes;"><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">BC3Z-9D430-E<o></o>
</td><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">Vacuum Harness<o></o>
WARRANTY STATUS:<o></o>
EligibleUnder Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are notaltered by a TSB. Warranty/ESP coverage limits are determined by the identifiedcausal part and verified using the OASIS part coverage tool.<o></o>
OPERATION<o></o>
DESCRIPTION<o></o>
TIME<o></o>
</td></tr><tr style="mso-yfti-irow: 1; mso-yfti-lastrow: yes;"><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">131007A<o></o>
</td><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">2011-2012 F-Super Duty 250-450 6.7L: Diagnose And Replace The Wastegate Control Valve Vacuum Harness (Do Not Use With Any Other Labor Operations)<o></o>
</td><td style="padding: 2.25pt; border: rgb(0, 0, 0); background-color: transparent;">1.1 Hrs.<o></o>
DEALER CODING<o></o>
BASIC PART NO.<o></o>
CONDITION CODE<o></o>
9D430<o></o>
v3<o></o>
«Recalls<o></o>
Old Jun 13, 2014 | 09:09 AM
apd966's Avatar
apd966
My 2012 F250 SD with 45300 miles is doing the same thing. A 30 second or so long loud hum/buzz after shut down. Called Leif Johnson Ford here in Austin, service advisor said he knows about the issue. Have appt. on Monday to bring it in with my TSB 13-10-7 in hand. IMO if a TSB is issued for a problem and they say its normal then why a TSB in the first place. Fix it Ford.
Old Jun 14, 2014 | 02:44 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Thank you for the post .........
Mine has been doing this since 30K miles. I now am at 44K miles.
It seems to only do it if the engine is fully warmed up. (hot)
Old Jun 14, 2014 | 09:42 PM
GCLL's Avatar
GCLL
I assume this is covered under the 5yr/100,000 engine warranty right? Has anyone had this repair done to confirm?
