Aftermarket Trans coolers for E40D
Back when I had my '97 F-250 7.3 PSD, I purchased this cooler but never installed. Although it is about 10 yrs old, it is brand new in the box.
Is this technology still current or are there better coolers?
Are these type of aftermarket coolers recommended for the E40D?
I run my truck in a HOT part of SoCal. I will be towing a travel trailer, other times a 3500# boat, and in future, perhaps an over head camper with boat in tow.
Does my truck have an oem trans cooler? My manual shows a tube that is called a cooler?
The cooler pictured is the all aluminum model (#LPD-4739)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
That is a stacked-plate type cooler, it's current technology as opposed to this tube & fin style cooler:
Imperial Econo-Kool® Transmission Oil Cooler 242010: Upgrade with the best Transmission Cooler(Add-On,Not O.E.) at Advance Auto Parts
The stacked plate design has more surface area for cooling. I'd go ahead and install it along with a trans temp gauge with the sensor in the pan if you're concerned about temperature (as every auto trans owner should be).
I plan on removing my radiator cooler and just running a big external plate cooler.
on
Way back when I bought my 91 Bronco (in 1993) I was told the E4OD needed extra cooling and I should add a cooler. I can't remember who told me but I was cautioned not to use the tube-and-fin type but to be sure to get the kind you have with the stacked plates. I bought the biggest one they had (I think it's a TransCool brand) and installed it. That E4OD trans went 250K miles and was still working when I pulled it out to do my diesel conversion. I still have the cooler but I don't have any trucks with auto trans now.
Every once in a while I look for a trans cooler to replace the additional one I have. The reason why I don't like the one I have now is it uses rubber hoses to connect and the clamps often leak. I'd like to find a small one (maybe 12" x 12" like the one I have now) that has fittings on it so I can get some lines made and screw on there. I thought about seeing if I could solder some sort of nipple on the inlet and outlet of an aftermarket one but I am not sure how much money I'd waste doing that.
I also had the idea to replace the lines to and from the trans with something that has a larger diameter, haven't done that yet though. If I do this I want to have some lines made but I am not sure what ones will be flexible and better than what I have now for cooling. I am sure the steel lines provide some cooling effect as the fluid runs in them but all the flexible lines that I know of have some sort of insulation on them.
I've read about install sending unit in inspection port but not directly into pan. That would require a fitting installed into pan, correct?
There are two useful places to measure temperature, depending on what you want to know. You can measure at the feed line to the cooler, which would get you the highest peak temperatures of your fluid as opposed to the temp in the trans itself, since this oil is leaving the torque converter after having already circulated thru the trans (the TC will heat it up further, so temps will read higher than what they actually are inside the trans)...
Or you could measure in the pan or inspection port, this is transmission operating temperature. It's where Ford takes the measurement at (sensor in the pan for the PCM) and gives an idea of what's really going on. I have done it both ways and prefer the pan.
Before you ask me how I mounted my sensor... I have an OBDII truck so my SGII (mounted in dash) just reads it out from the PCM.
