Sponsored by: Real Truck
rumble strip syndrome fixed
Old Jul 4, 2003 | 08:35 PM
pexhere's Avatar
pexhere
after tearing apart the front end of my 99 psd, i found the bearings that support the front axles were non existent. i replaced them and replaced both axles, due to the extensive wear on the journals. the lack of bearings caused the axles to vibrate against the hub, causing the rumble strip effect. im not saying its a fix for other problems, but it took care of mine. just pry the end u-joints up...if you got a lot of play...you found the problem. the bearings are not greasable, in the truck, just when you put them in. ford way of keeping the parts dept busy i guess. just thought id share the info.
ExcursionQ13
Oct 13, 2014 06:46 PM
DieselDude92
Sep 24, 2013 04:48 AM
Jspafford
May 8, 2008 07:16 PM
redmaple
Dec 31, 2005 12:29 AM
