Pertronix Ignitor III Install problems
Old Apr 19, 2014 | 04:56 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Thought I'd install my new Pertronix Ignitor III today and see how the ole Y-Block perks up.
Here's what I've got.
Here it is.
Now the problem begins. The instructions say to put the prong on the Ignitor III in the threaded Condenser hole. But there are two problems:
ONE
If you could install it the unit is in the way of the vacuum advance arm.
TWO
There's a bulge on the distributor plate that won't let the unit sit flat.
Anyone run across this problem?? Nothing is as easy as it seems
Old Apr 19, 2014 | 05:03 PM
bjmayberry2
Forgot to add. I bought an after market Distributor from Oreille's and it won't fit in it either???? Hits the vacuum advance arm too
Old Apr 19, 2014 | 05:38 PM
DR Smith's Avatar
DR Smith
I had a problem with my 56 not fitting . Turned out it had a 57 distributor , both vacuum and mechanical advance . I called the company I bought it from , they exchanged it . Even though it was not their fault .
Old Apr 19, 2014 | 05:53 PM
Jules The Great's Avatar
Jules The Great
I had the same problem. Bought the Y block one only to find my distributor was a 57 or later. You can you the pertronix for the later Ford distributors and it will work.
Is your vacuum advance curved? If so you have a later distributor.
Old Apr 19, 2014 | 07:41 PM
bjmayberry2
Yes the vacum advance arm is curved.
Old Apr 19, 2014 | 08:11 PM
PonderosaF1's Avatar
PonderosaF1
Pertronix 3
I sell these all day from our Hot Rod shop and the 71282 is for the straight vac adv rod and the 71281 is for the curved flat vac adv rod that follows the inside curvature of the dist body.
Old Apr 19, 2014 | 09:43 PM
Jules The Great
Here is the 71281 next to the original plate.
I do not have the vacuum installed here but that is what it looks like in the distributor you can see the curved arm right above the distributor body.
Here is what the inside of my distributor looks like.
Old Apr 19, 2014 | 10:12 PM
bjmayberry2
Thanks PonderosaF1 & Jules,
That's what my distributor looks like! I ordered a 71281 from Advance Auto for $95.34 tonight. Can't find the receipt for the 71282. Bought it about a year ago, just never got around to installing it or the new distributor.
How do you like it? I hope all this trouble is worth it
Old Apr 19, 2014 | 10:29 PM
Jules The Great
It is amazing and I love it. I drive my truck everyday and never had any trouble starting all winter, although it does not get too cold in WA.
I also bought the flamthrower III coil like what you have there I think.
I am happy and would buy again if needed.
Old Apr 19, 2014 | 10:35 PM
PonderosaF1
Pertronix 3
Are you sure you are to receive the 71281 for 95.xx?.You might want to double check to see you are not going to get the 1281?
Old Apr 20, 2014 | 07:28 AM
bjmayberry2
Yes it's a 71281. When I searched for a 71281 Advanced Auto's site had them with a $40.00 off code (A124) for purchases over $100.00.
Old Apr 20, 2014 | 07:39 AM
bjmayberry2
Just went back on Advance Auto's site and the code doesn't work??? The new discount code is E41 and not as good of a discount it's $114 now. https://shop.advanceautoparts.com/we...mWEw0dcE7po%3D
I must have just got lucky.
Old Apr 29, 2014 | 02:13 PM
bjmayberry2
Got the new 71281 yesterday, and installed it today. Piece of cake, Fired right up! Changed the cap & rotor as well. Took it out for a test run. WHAT A DIFFERENCE. Sorry I was so wrapped up in installing the stuff I forgot to take pictures but Jules photos are exactly how it looked.
Am in the process of trying to send my 71282 back. Not as easy
Boostingaz
49
Nov 15, 2017 11:52 AM
df85732
Jun 2, 2017 10:23 AM
TMI
Jul 15, 2016 07:25 AM
68cabby
Mar 18, 2013 08:31 PM
Jeff Dodson
Jan 25, 2009 07:14 PM
