Sponsored by: Real Truck
Shock change out
Old Apr 17, 2014 | 08:53 PM
DieselVol's Avatar
DieselVol
Shock change out
Is there some special tool to use to help with the bottom nut on the front shocks? I can't find anything to put on that nut to hold it in place while I ratchet the bolt end. It's about to drive me to drink.
Old Apr 18, 2014 | 05:51 AM
redford's Avatar
redford
FTE Leadership Emeritus
It's all in this video.
Old Apr 18, 2014 | 06:14 AM
DieselVol's Avatar
DieselVol
Originally Posted by redford
My setup is completely different. The top of the shock is the pin type and the bottom has to be reached from below in a very tight area that will not allow a regular open end wrench access to the nut. It's a 2006 setup. Not sure why its different, buts not at all like the video. Thanks anyway.
Old Apr 18, 2014 | 07:10 AM
meborder's Avatar
meborder
what vehicle are you working on?
usually on the shocks with the top post, i hold the shock body or rod with a pair of channel locks while i turn the top nut with an impact.
but i'm not sure if that is what you are asking or not.
here's a video of what i'm talking about.
if you can't get a wrench underneath to hold the bottom nut, you can just hold the top of the shock with a channel locks.
an impact helps. if you are lucky it will just twist the treads off.
Old Apr 18, 2014 | 07:20 AM
DieselVol's Avatar
DieselVol
How To Install Replace Front Shock Absorber Ford Explorer Ranger Mountaineer 95-05 1AAuto.com - YouTube
It's an '06 F250 and I'm talking about the bottom of the front shock. The bolt goes in from back to front and the nut fits into a housing from underneath and engages the bolt there. I'm suspicious somebody has changed out the nut, bolt, or both. If this was standard, I'm pretty sure somebody on this forum would know what I'm talking about.
Old Apr 18, 2014 | 08:44 AM
CPB1's Avatar
CPB1
The nut is supposed to be incorporated in a one piece tab/nut. There are no tools used to hold the nut. You hold the tab and start the bolt onto the nut and tighten the bolt.
I think someone has changed yours, maybe lost the tab/nut and stuck a regular nut on it.
May be a Ford only item. Auto Nation Ford has the best prices.
Old Apr 18, 2014 | 01:39 PM
MC5C's Avatar
MC5C
Exactly. When I changed the shocks the bottom front bolt was literally the easiest. The upper nut on the pin drove me to drink... No clearance for a power tool, one seized up, at the end I cut the pin with a tiny little body saw.
Old Apr 18, 2014 | 02:55 PM
DieselVol's Avatar
DieselVol
I spoke with the local dealer. My nut is wrong, not sure about the bolt. I'm going by to order the right ones. On the other issue, I found the tops to be easy since I started using an open end wrench. It's tedious, but my knuckles are intact.
Old May 4, 2014 | 11:02 PM
DieselVol's Avatar
DieselVol
Update
Got the correct nuts and bolts from the dealer and finally got them installed today. The bolt would not fit through the metal casing in bottom hole. I ended up driving that casing out of the bottom hole and then was able to fit the stock bolt through the rubber/plastic/whatever that stuff is that pads the bottom hole of the shock. Is it a problem to not have that casing in there? ?
tps93ranger
20
Feb 20, 2014 06:52 AM
xamack24
1983 - 2012 Ranger & B-Series
Feb 5, 2013 10:51 AM
02GrayPowerStroke
Apr 22, 2009 06:36 PM
BrianA
Mar 22, 2004 02:22 AM
lovethetruth
Aerostar
Jan 21, 2004 08:59 PM
