I have a 75 f100 300 inline six. While removing the front clip I managed to cut the headlight wire. So I purchased a new headlight wiring harness from Lmc truck. Well what I need is a harness that has the directional signal side marker and the headlight all in one. When I unplugged the old one all three are plugged in on one plug. Any help would be great.
The part# you need I believe is D7TZ-13076-A which are obsolete. Finding a NOS one is pretty hard. Took me quite a while to find one. Splicing may be a better option.
I did a search and couldn't locate any Ford dealer or obsolete parts supplier that has any .
EDIT: I went back and checked. D7TZ-130760-A is the superseding part number. The original part number was D5TZ-13076-A. I located three of those.
Wesley Obsolete Parts, Liberty, KY has 1 (606) 787-5293
Freese Motor, Monticello, IA has 2 (319) 465-3541
