94 manual problems
Old Apr 17, 2014 | 10:54 AM
nick_94's Avatar
nick_94
94 manual problems
ok guys Im new to this forum and new to the manual world also so I just bought this 94 half ton with the 4.9 in it kinda just looked at it drove it around the block and it drove fine shifted fine all that so I snatched it up and drove it home the 55 miles let it set for a few days go to jump in it and I hear this grinding noise not to loud just though it was an old truck well drove it around for a while then it wont shift right then its shifts ok then back to not shifting right then I hear this loud growl took it home checked the fluid in the tranny and sure as shhhh put 3 quarts in it to fill up and its still doin the same problem any ideas would be helpful thanks
Old Apr 17, 2014 | 11:07 AM
Mike1's Avatar
Mike1
When you say it won't shift right, do you mean you can't get it to go into gear or it grinds going into gear? Or is it just "growling" as you're driving down the road? If it's hard going into gear, check the bushings at the clutch pedal, maybe they're worn out. Check to make sure that your firewall isn't flexing when you push in on the clutch. Check to make sure your master cylinder if full of fluid and not leaking anywhere.
Old Apr 17, 2014 | 11:12 AM
nick_94's Avatar
nick_94
it will go into gear then when u down shift If wont go back into gear until u stop doesnt grind goin into gear 1st gear grinds loud when in gear sometimes master is full also then when u push clutch in all grinding stops
Old Apr 18, 2014 | 07:20 PM
Mike1's Avatar
Mike1
Almost sounds like the throw out bearing is shot.
Old Apr 19, 2014 | 07:46 AM
nick_94's Avatar
nick_94
Well i pulled the top cover off to inspect it and found alot of metal shavings so i pulled the tranny out and i spun the shaft by hand and it would gring and then get stuck so im asuming its shot my nieghbor is a ford mechanic he said the throw out bearing felt good and the slave isint leaking but they put a china made clutch in it and its almost bad so im just goin to replace it all lucky for me!
Old Apr 19, 2014 | 08:27 AM
Mike1's Avatar
Mike1
You pulled the top off the trans and its full of grinding and the input shaft is sticking. ... sounds like a full trans rebuild is in order.
Old Apr 19, 2014 | 03:20 PM
nick_94's Avatar
nick_94
Yea i found one with 120k on it for 300 bucks its still in the truck so i get to hear it an see how she shifts
Old Apr 20, 2014 | 05:36 PM
nick_94's Avatar
nick_94
Well now the guy tild me to make sure i have the mazda tans in mine and the onther number i get off the trans are
F1TA
GC
B342326
Any one know what this means thanks for the help
matthewscott272
1983 - 2012 Ranger & B-Series
Aug 17, 2017 02:49 PM
Lex Dayton
Apr 6, 2012 08:01 PM
robin22m
Mar 24, 2009 04:31 AM
zach_barrow
Feb 4, 2008 09:10 PM
kelsted
Jan 31, 2005 09:52 AM
