I had problems with my wipers not turning off. That problem went away. Yesterday truck popped code po360. Switched coil ten with eight cleared codes. CEL stayed off. When I started truck ETC wouldn't work. Won't light up no power. Checked fuses they are fine. It was ten below freezing today I need heat. Any idea's?
I was told my wipers were acting up because I have a famous leaking sunroof. I turned the heat on the floor on hi for half an hour and wipers went back to normal. What is the GEM? What does it look like ? Could this be the problem with my heater?
