Two big problems today
Old Apr 16, 2014 | 10:13 PM
tbm3fan's Avatar
tbm3fan
First: Steering column
Can't figure out how you remove the whole column with that lever buried inside for the automatic transmission. Of course, the manual has absolutely nothing on this particular subject. The bolts inside, the ones at the rag joint and the one for the trans arm pretty obvious.
Second: Tailgate
Problem here is that I can't get it back on. I cannot recall how I dealt with those two lower hinges. Can't install them in the gate as the gate won't slide straight in. If I try to insert one side and then angle the other side down or up to slip the other hinge in then I run the big risk of damaging new paint. Just spent an hour with my wife and made no headway. Luckily we didn't chip anything which would have meant a repaint.
Old Apr 17, 2014 | 02:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by tbm3fan
Steering column
Old Apr 17, 2014 | 05:53 AM
User 71024's Avatar
User 71024
I don't know what your question is on the column.
As for the tailgate, there is no trick, you just have to be real carefull. But it may be easier with the bumper off.
Old Apr 17, 2014 | 06:37 AM
jowilker's Avatar
jowilker
Mike, You mount one side of the hinge, place the end of the gate over it with the other side raised about a foot, put the hinge piece in the cuff and lower it into place, add bolts.
Arm braces install to truck, with reverse bend connect to tail gate, extend and they should work.
Having a helper is recommended.
John
mbrownone
17
Apr 14, 2022 11:52 PM
tbm3fan
Oct 7, 2013 04:50 PM
351Cleveland C4
Jul 24, 2013 01:10 AM
76HighboyGuy
Jun 3, 2011 12:10 PM
cbremer
Jan 30, 2000 10:01 AM
