So I have an ongoing issue that I can't seem to pinpoint with my front drive shaft. It squeaks awful when I am driving, especially at low speeds. I recently replaced my front output seal on my transfer case thanks to all the help to the FTE crew and it has been working great with no leaks!
Am I looking at needing to replace the U Joints to stop that squeaking on the driveshaft? I can figure any other reason it would be making noise. I have lubed them (they have grease points) and sprayed lubricant all over just to try and reduce the noise level with no luck. Anyone got any pointers or suggestions?
