Sponsored by: Auxito
Truck squeeks when backing up
Old May 19, 2005 | 03:09 PM
Tony G.'s Avatar
Tony G.
I'm getting a squeeking noise when I back up. It sounds like it's coming from the front end of the rear drive shaft. Doesn't do it in drive. It looks like there is some wear on the drive shaft where it comes out of the transfer case.
Old May 19, 2005 | 10:38 PM
ksuroper's Avatar
ksuroper
I am almost positive that you have a u joint going out. You can move your drive shaft around and look at the u joints to see if they have any play. Mine was doing the same thing. U joints solved the problem.
Old May 21, 2005 | 05:42 PM
Tony G.'s Avatar
Tony G.
I think that's the problem after checking it out. I'm going replace ujoints and see if it works. Thanks for your help!
