Modular V10 (6.8l)
fuel tank excessive vacum pressure
Old 09-08-2014, 10:56 AM
rmopar's Avatar
rmopar
rmopar is offline
2009 v10 creating excessive vacuum pressure i can hear it trying to suck vacuum around the gas cap. possibly bad cap but i think it is some thing more
Old 09-08-2014, 12:42 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Excessive pressure or excessive vacuum? They are opposite conditions.
Old 09-09-2014, 09:22 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The caps on these fuel systems have been completely sealed for quite some time.
If there's vacuum OR pressure, something is wrong with the evaporative emissions system.
Can you scan for codes with an OBD-II/CAN scanner? Autozone or some other local parts store might have something you can borrow for a few minutes.
Record all the codes (if any) and report back. There might not BE any, but it's worth a shot to check.
Old 09-09-2014, 12:25 PM
rmopar's Avatar
rmopar
rmopar is offline
vacuum
there are no codes and the tank has excessive vacuum and it is trying to do all the venting through the gas cap
Old 09-09-2014, 01:58 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like either the charcoal canister is clogged, or the solenoid isn't activating. I don't know a whole lot about what the later trucks have for evaporative emissions.
But usually what happens is when pressure in the tank builds up, it feeds a charcoal canister that collects the vapors. When the engine is running, the computer opens a solenoid (purge valve) between the canister and the intake manifold to suck the vapors out of the canister - a "purge".
If the engine is off, and there is vacuum in the tank, something "ain't right"
Corey Rice
1999 to 2016 Super Duty
07-25-2019 06:54 AM
DBGrif91
09-30-2013 09:10 PM
kaduh
01-26-2010 05:23 PM
ChasA
Modular V10 (6.8l)
06-28-2007 08:27 AM
geson
07-17-2004 11:08 AM
Quick Reply: fuel tank excessive vacum pressure
