electronic ignition conversion
Old Apr 17, 2014 | 01:24 AM
TigerDan's Avatar
TigerDan
I originally made a heat sink from a piece of 1/8" aluminum flat stock I had. Just replaced it with this:
12 bucks from Amazon. I guess it's made for a stock GM module and it doesn't quite fit an aftermarket module, but it only took a couple minutes to drill some new holes.
Amazon.com: ACDelco 10474610 Ignition Module Heat Sink: Automotive Amazon.com: ACDelco 10474610 Ignition Module Heat Sink: Automotive
Old Apr 17, 2014 | 08:24 AM
70-360fe's Avatar
70-360fe
I have some old junk electronics I haven't tossed yet maybe I can find something similar inside.
I
Old Apr 17, 2014 | 08:45 AM
70-360fe's Avatar
70-360fe
Originally Posted by Uni Moe
My distributor has a little slop so I was thinking it might be time to rid my stock 360 of the points. What is everyone using? I saw some HEI units on Fleabay that say one wire hook up. 190868049067 for example. Any disadvantage to HEI type? Still room for the stock air breather?
Read that they work good but on some of the cheaper ones some people have had the bearings go out and the dist. blows up. Ford durasparks are built different and don't have this problem. With your 360 I think you have to get a 2 inch carb spacer/and or a 14 inch air cleaner. DUI is nice but expensive. This is why I'am going to do a ford duraspark dist with a gm module. Pro's and cons with each system and you could argue all day long which is better. No matter which way you go it will be a improve over stock points.
Old Apr 17, 2014 | 08:33 PM
BobbyFord's Avatar
BobbyFord
My truck has a recurved Duraspark and an MSD box. Wiring is minimal and you get an adjustable rev limiter
Old Jul 23, 2014 | 02:35 AM
69issofine's Avatar
69issofine
gm module
don't they make a racing version of this module? the original version doesn't work well below 12v.
2zwudz
Oct 28, 2013 01:36 PM
BrotherMabe
Apr 2, 2013 08:59 AM
doc66
Apr 27, 2009 10:28 AM
70_f100
Aug 20, 2005 12:48 AM
F350 Grandpa
Jan 3, 2003 09:04 PM
