2004 xlt Climate Blower
Old Apr 15, 2014 | 08:47 AM
garmford's Avatar
garmford
Over the weekend I realized that the blower doesn't run on the 2 lowest settings of the turn dial but does run on the highest. There is no difference between defrost or vent. Any help would be appreciated. Thanks!!
Old Apr 15, 2014 | 09:20 AM
Mike189677's Avatar
Mike189677
You need a blower motor resistor. I have the part # somewhere if no one has posted it by the time I check back. It was like 22 bucks from the local dealer.
Old Apr 15, 2014 | 11:06 AM
garmford's Avatar
garmford
I figured it is something simple. Is it easy to get at?
Old Apr 15, 2014 | 06:26 PM
cheezit's Avatar
cheezit
Yup not to bad. Its on the evap case
Old Apr 15, 2014 | 07:14 PM
garmford's Avatar
garmford
I just replaced the resistor but it didn't change. One of the prongs from the old resistor rusted thru and broke off in the connector. I thought I got all of it out and the new one went in without any struggle. I did lube it up with dielectric grease. Do you think I would need to replace the connector?
Old Apr 15, 2014 | 07:36 PM
cheezit's Avatar
cheezit
Did you check it with an ohm meter?
Old Apr 15, 2014 | 08:05 PM
garmford's Avatar
garmford
No I did not. Next time I get a spare minute I will do that.
GlenPxC
Jun 5, 2019 08:43 PM
llaugerm
Jun 25, 2015 12:53 PM
cwnitsuj
2004 - 2008 F150
Aug 7, 2013 07:19 AM
jippy
1983 - 2012 Ranger & B-Series
Mar 21, 2010 09:21 AM
CanadianSmokie
Jan 4, 2008 11:49 AM
