Unknown clanking
Old Apr 15, 2014 | 06:34 AM
Walwal44's Avatar
Walwal44
Unknown clanking
Well this morning i hit a pot hole amd everytime the wheel comes back after turning left it makes a clanking noise. I pulled over and turned the wheel while i stopped and it wont do it. It only happens when im moving. Please help.
Old Apr 15, 2014 | 06:55 AM
schmoken's Avatar
schmoken
Pop a swaybar link?
Old Apr 15, 2014 | 07:11 AM
Fordman96's Avatar
Fordman96
A clunking while moving.. how hard did you hit the pole? What kind of front axle do you have? Maybe you snapped a u-joint inside the axle on the spindle and it hits output shaft at just the right angle.
Old Apr 15, 2014 | 07:28 AM
Walwal44's Avatar
Walwal44
I hit it pretty hard because i dump truck was coming the other way and it was filled with raim water and i didnt know it was that deep i was going about 30 and i think its called a twin i beam... Its what ever one thats not a solid front axle.
Old Apr 15, 2014 | 07:50 AM
Fordman96's Avatar
Fordman96
The front wheel still rolls correct right?
Old Apr 15, 2014 | 08:05 AM
Walwal44's Avatar
Walwal44
Yea but i do have a slightly warped rotor but it is not noticable
Old Apr 15, 2014 | 08:21 AM
Fordman96's Avatar
Fordman96
1983 Ford Bronco Diagrams picture | SuperMotors.net
is the full picture.
I could be dead wrong but the clunking could be from a snapped u-join in the shaft assembly if you hit it just right. As the wheel turn the shafts could be hitting each other.
Old Apr 15, 2014 | 09:42 AM
Walwal44's Avatar
Walwal44
I am going to check my tie rod and shock tomorrow to see if thats the problem ill check that next
Old Apr 16, 2014 | 07:47 PM
skrappy's Avatar
skrappy
I just had both the left and right axle u-joint replaced at a local shop because one went out near where I work. Was not overly fun to pay for.
tjgalinski
Aug 28, 2015 08:42 AM
Baatzy
May 3, 2015 05:01 PM
ethand320
1997 - 2003 F150
Feb 27, 2014 09:41 AM
myke57
2009 - 2014 F150
Jan 23, 2011 06:35 PM
