ford motor
Old Apr 15, 2014 | 04:18 AM
704eric704's Avatar
704eric704
ford motor
I HAVE A D8VE-0615-ASA
WITH EITHER 806 OR 6 UNDER THEM NUMBERS. DOES ANYBODY HAVE ANY INFO ON WHAT I HAVE? PLEASE AND THANKS
Old Apr 15, 2014 | 07:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 704eric704
I HAVE A D8VE-6015-ASA WITH 8D6 UNDER THE NUMBERS. DOES ANYBODY HAVE ANY INFO ON WHAT I HAVE?
With a D8VE block casting number prefix, it could be a 302 or 351W from a Lincoln Versailles.
8D6 = Block cast April (D) 6, 1978 (8).
Old Apr 15, 2014 | 12:18 PM
baddad457's Avatar
baddad457
That casting number is for a 302 block found in any Ford/Lincoln or Mercury car, truck or van in 1978 or 1979. I've had two of these blocks. It has a boss cast in the rear above the rear main bearing saddle for a crankshaft position sensor, hence the "V" in the prefix. Neither block I had, had this boss drilled for the sensor.
Old Apr 15, 2014 | 02:16 PM
NumberDummy
Uh huh, well I know from past experience it's useless to argue, but whether you believe it or not, the 1978 Versailles used a different block and crankshaft than other 302's.
Despite its Lincolnesque grille and Continental Mark type deck lid, the 1977/79 Versailles...like its cousin...the Mercury Monarch, is basically a rebadged Granada.
Old Apr 15, 2014 | 04:14 PM
baddad457's Avatar
baddad457
All vehicles in 78=79 used that block if equipped with a 302. Irregardless of what you're reading in your parts manuals. Both blocks I had were D8VE's without the crankshaft sensor hole and as such would not have been used in the Lincoln with it's electronic feedback carb. I've heard of quite a few that were pulled from 78-79 pickup trucks on this site and others. Ford rarely used more than one block casting in production. The D8VE came in two castings, one with the A3 suffix and the big main capped version with the A3A suffix. Other than the caps, the two blocks are identical.
Old Apr 15, 2014 | 04:25 PM
NumberDummy
I know it's a study in futility to discuss this, but...
D94Y-6010-A (replaced D84Y-6010-A) .. 302 Bare Block-1978/79 Versailles with EEC
D84Y-6303-A .. 302 Crankshaft, includes ignition pulse ring-1978 Versailles.
1979 LTD/Grand Marquis 351W sold new in CA also came with EEC
Old Apr 15, 2014 | 04:30 PM
baddad457's Avatar
baddad457
Those are the PART NUMBERS you're quoting here, not the engineering numbers actually found on the block and crank. You shold know by now that you will never find the part number on a part, it will only be found on the packaging it came in. Or on a tag affixed to a new part. It's only a futility because you refuse to acknowledge this fact. You claim to be a retired parts guy, but yet you're ignorant of this fact.
Old Apr 15, 2014 | 05:50 PM
NumberDummy
Uh huh...I'm well aware of these facts.
There's one thing I will acknowledge, discussing anything with you that we both agree on.
In previous encounters (excepting WWII USN submarines), you are always right, while I am always wrong.
Old Apr 16, 2014 | 11:02 AM
baddad457's Avatar
baddad457
If you are aware of the fact that part numbers and engineering numbers are not the same thing, then why even mention them here ? The OP posted the engineering numbers off a block and wanted to know what they indicated, not the part numbers. There could be two different part numbers for the same part, in this case an engine block. This can be attributed solely to the crankshaft position sensor, the block without the sensor hole drilled would rate one part number, the block with the sensor hole drilled would rate a different number. The block without the sensor boss drilled would not be able to be used in the Lincolns (unless their whole electronic feedback carb system was ditched for a standard carb setup) You stated that the block in question was not used in other applications, you are wrong about that. If you were right, then what was the original application for the two blocks I've had that did not have the sensor bosses drilled ? Using your logic, these blocks did not exist. Yet they did.
77150KIDD
Mar 24, 2021 06:28 PM
72rtchallenger
Nov 19, 2017 05:19 PM
vortech
Aug 7, 2008 08:09 AM
swampfox 1954
Sep 19, 2007 06:39 PM
dbrown13
Mar 31, 2004 08:40 AM
