Ball Joints
Old Apr 14, 2014 | 09:46 PM
04badford's Avatar
04badford
Ball Joints
Well boys I think it's time for some front end work, Moog or is there other brand that is just as good for the upper and lower ball joints, also tie rod ends. 04 ext cab 2wheel drive ,thanks all
Old Apr 14, 2014 | 09:52 PM
BLADE35's Avatar
BLADE35
Theres them kind Bismic Has
Field rebuildable
I went Moog
But I think a Servicable OEM BJ would be sweet too Last I heward Ford added grease zerts
Old Apr 14, 2014 | 09:56 PM
BLADE35's Avatar
BLADE35
IIRC Mark runs Dynatrac's there spendy and IDK anything on how they wear
Old Apr 14, 2014 | 09:59 PM
04badford's Avatar
04badford
Heyyy oem bj, I never
Old Apr 14, 2014 | 10:22 PM
BLADE35's Avatar
BLADE35
lifer warrenty on moog
IDK
If my Moog fails I am only out seals FWIW
Old Apr 14, 2014 | 11:05 PM
04badford's Avatar
04badford
I like the Idea of being able to grease them, the OEM ones now went 167 thou, who has the better deal, I took my truck over to a 4x shop 1200 for the front end work that's with Moog.
Old Apr 14, 2014 | 11:10 PM
9228.bobcat's Avatar
9228.bobcat
I run moog never really had a problem with them. Not to bad to change. Put the new ones in the freezer over night and they go in a little better.
Old Apr 15, 2014 | 02:09 PM
Forest's Avatar
Forest
I've used Moog twice ('03 Excursion 4x4 and '05 Excursion 4x4). The latest set have gone almost 100,000 miles with no problems and still very tight suspension.
Old Apr 15, 2014 | 02:15 PM
Oh5dually's Avatar
Oh5dually
I've heard of people doing this... but now I have an excuse to try when the sun pokes out again!
Old Apr 15, 2014 | 09:33 PM
04badford's Avatar
04badford
Dynatrac JP44-2X3050-A SET OF 4 JK PROSTEER BALL JOINTS
Anybody running these Dynatracs or would Moog out do them?
Old Dec 2, 2014 | 06:57 PM
04badford's Avatar
04badford
Ended up going with Moog grease able fittings 2004 2wd 350 extended cab
1. Moog upper k80028 times 2
2. moog lower k80027 times 2
3. moog tie rod es3418t
4. moog tie rod es3417t
5. moog tie rod ds1434
6. moog tie rod ds1433t
didn't have to do the Idler arm but here are some Alignment Cam numbers
1. 2004 2wd 350 ext = Procomp # EXT-594
2. 2005/2015 4x4 350 = Procomp # EXP-599
Old Dec 8, 2014 | 08:28 AM
DSMMH's Avatar
DSMMH
I did mine this spring. Complete from steering gear to hubs. All new MOOG ball joints, tie rods, control arms and adjusters. Replaced hubs with Timken hubs. I purchased those parts. Had a friend of mine who was an out of work mechanic do the job at his house. $1200 for the job and that included $350 for incidental parts and freeing my lower slide pins on my front brake calipers. Job cost me about $1800 turn key. I could not believe the difference. Very, very pleased.
Ed
Old Dec 8, 2014 | 02:24 PM
Yahiko's Avatar
Yahiko
Would of liked to have a look at that ball joint but I got this.
This link is not valid.
Of all the problems with Moog I think it was do to people not installing
then correctly or not torquing them to the right level.
Sean
Old Dec 8, 2014 | 10:50 PM
BLADE35's Avatar
BLADE35
I've only got maybe 20,000 on my moog ball joints but they're still holding up strong checked in the other day
But my opinion any ball joint in a 6.0L that could go 100,000 miles is a solid part
These ball joints take a brutal beating from the weight of the diesel engine plus a lot of us are running lift kit and bigger tires which gives them an extra hard pounding
My OEM original went almost 100,000 miles with bigger tires and a lift kit my front springs alone have a leafs if I recall correctly which makes it
Old Dec 9, 2014 | 04:54 PM
Tim C's Avatar
Tim C
Moog sucks! my factory 03 ball joints went at 50000 miles, the moogs I put in then have 200000 on them with 37-35" tires.
