ok whos a supercharger injection 351m/400 whipple expert ?
my plan is to build up a 400 with a pair of cj v4 oc heads with aprox 76cc , an aprox 32cc forged anodised piston set with a ecu set up sequential spark and injection intake toped by a whipple with a valley mounted intercooler sunk down in the valley with a modified manifold (that I will build out of a twin carb cleveland one)
my estimate with them internals will put it at approx. 8 to 1 cr and with the 203 whipple at 12 psi it will end up in the area of an aprox high 13's 1 compression ratio
with hopefully an aod (or e4od) matched up behind it and ending with a 9" ratio of 3.25 to 1 in heavy ltd street car
so ok whos a supercharger injection 351m/400 whipple expert , what you kink and what am I missing or should be thinking about if any thing
also have a crower cam for this build and can post details and can discuss my ideas on the injection induction set up I have planned even the can sensor pick up and crank pick up I have planned
79blakemaggard
17
05-01-2015 11:43 AM
Jon351m
01-21-2011 08:27 AM
