98 Expy running like crap
Old Apr 13, 2014 | 10:35 PM
teamlx88's Avatar
teamlx88
I have a 1998 Expy Eddie Bauer with 125k miles on it that lately has been running like crap but I have no trouble codes to go on. When the truck is cold it runs fine however as soon as it warms up it starts to idle rough and misfire under load. I scanned the truck for fault codes and got nothing. I checked all the coil connections, vacuum lines and pcv for any signs of failure and found nothing. Does anyone have an idea what else I could check?
Old Apr 14, 2014 | 09:58 AM
r2millers's Avatar
r2millers
Pull you COP's each to see if you have coolant in the plug holes. With a manifold leak, once the engine warms and starts to vaporize the antifreeze in the plug hole, the moisture/vapor increases the resistance and just might set off a misfire.
Clean your MAF also, check your fuel pressure and/or change your fuel filter for starters.
Old Apr 14, 2014 | 10:06 AM
alloro's Avatar
alloro
The coolant sensor could be bad too. If it's sending a signal that the engine is still cold, then the air/fuel mixture won't be correct.
Old Apr 15, 2014 | 02:21 PM
teamlx88's Avatar
teamlx88
OK, new fuel filter and cleaned the MAF with no change.No anti freeze leak either. I am however getting a code on my scanner now (still no CEL though). Its a p1000- on board pcm self test not complete. What the hell is this??
Truck is still acting up. Sometimes it feels like its gonna stall, other times it idles great. One minute Im getting engine vibration and sputtering through the exhaust then suddenly its fine for a few minutes.
Old Apr 15, 2014 | 03:57 PM
alloro's Avatar
alloro
The P1000 DTC code is a manufacturer specific code. In the case of Ford vehicles, it simply means that the OBD-II monitor tests are not complete.
Old Apr 15, 2014 | 04:56 PM
r2millers's Avatar
r2millers
Check your connections to the PCM. It sounds like an incomplete signal.
I had the same issue on my daughters Mini sometime back.
Rechecked and secured connections and we're then good to go.
dunnc1989
Jul 11, 2015 06:51 AM
chev2ford
1997 - 2003 F150
19
Oct 24, 2014 10:31 PM
509freerider
Modular V10 (6.8l)
Jun 16, 2012 11:05 AM
davisenvy
21
Dec 21, 2008 07:30 PM
cvpi71
Apr 22, 2008 11:17 PM
