ecm replacement?
Old Apr 12, 2014 | 07:39 PM
wiarde's Avatar
wiarde
ecm replacement?
I can't find one online to replace mine I know it's bad tried to fix it and messed it up here's a pic if anyone could help me find one
Old Apr 12, 2014 | 07:58 PM
RIKIL's Avatar
RIKIL
Will this work?
90 91 Ford F150 F250 5 8L ECU ECM 351W E40D F0TF 12A650 R2A 69 C0L Warranty | eBay
or this...
http://www.ebay.com/itm/1990-1991-FORD-F150-F250-5-8L-ECU-ECM-351W-E40D-F0TF-12A650-R2A-C0L-WARRANTY-/130480203784?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e6139e808&vxp=mtr
Old Apr 12, 2014 | 08:03 PM
wiarde's Avatar
wiarde
I was guna get that one but if it's used like mine I'll be back to square one with bad capacitors. I tried looking at advanced auto but there are way to many there lol
Old Apr 12, 2014 | 08:08 PM
RIKIL's Avatar
RIKIL
All of them will be used. This one comes with a warranty so that is good.
As another option I have a card of a guy who will make them good again (test and replace everything that's needed). He also offers a warranty and I have used him so I'd recommend him. He has been very fair to me in the past. Let me know if you want it.
Old Apr 12, 2014 | 08:17 PM
wiarde's Avatar
wiarde
I don't have a good one to fix anymore or I would call that guy lol kinda burned my board that's why I was looking If I cant find a new one I'll get a used one I guess and have it fixed
Old Apr 12, 2014 | 08:20 PM
Tedster9's Avatar
Tedster9
If it's just capacitors that need replacing, that's an easy fix. Just don't cheap out on these or they won't last very long. The originals may have leaked the electrolyte out, or they will dry out and act more like a resistor. Testing for capacitance value won't tell you much, they need to be tested for ESR or "leakage" at their rated voltage. Even so, quality replacement caps from outfits like Mouser are only a couple bucks, some rosin core solder and an iron and yer on your way. Can save $$$.
It pays to ensure that working units have a good clean ground and good contact cleaner applied to the pins and connectors, and some type of corrosion preventive to keep moisture away from the connections.
Sent from my iPhone using IB AutoGroup
Old Apr 12, 2014 | 08:26 PM
wiarde's Avatar
wiarde
I burnt the bored trying to get an old cap out and the holes were.they were are a bit big now along with one of the printed circuits I burned on accident
Old Apr 12, 2014 | 09:11 PM
Tedster9's Avatar
Tedster9
Huh. I'm wondering for future reference - and this would look like hell - but electrically it wouldn't matter, if you could just clip the old cap off and try and realize enough of the old leads on top of the board and then solder the new cap to those. The idea being not to bugger up the old traces or anything like that.
Not to change the subject but my 64 F100 is 50 years old and dependable. Will my 09 Ranger even be repairable 50 years from now, all those chips and boards and golly knows what all. Thinking not.
Old Apr 12, 2014 | 09:13 PM
wiarde's Avatar
wiarde
That sounds like a good idea actually lol and I just ordered the one off eBay it seller told me he rebuilt it
Old Apr 13, 2014 | 10:15 AM
Conanski's Avatar
Conanski
When you get the PCM if the caps aren't swelled don't mess with it just put it in.
Old Apr 13, 2014 | 10:29 AM
wiarde's Avatar
wiarde
What do you mean by swelled ?
Old Apr 13, 2014 | 11:13 AM
Tedster9's Avatar
Tedster9
Just that, sometimes failed capacitors will bulge before they spill the contents.
Old Apr 13, 2014 | 11:18 AM
Conanski's Avatar
Conanski
Yes if the caps have nice flat tops and sides they're fine, they tend the bulge or balloon a little when they're breaking down.
Old Apr 13, 2014 | 11:28 AM
wiarde's Avatar
wiarde
Ok thanks I will look for that
Old Apr 13, 2014 | 12:00 PM
Tedster9's Avatar
Tedster9
They can certainly look fine and be trashed, an ESR or leakage test is the only way to tell for sure. If they are bulged then they are always toast.
Punchenello
Apr 12, 2015 04:10 PM
MudhenGIB
Oct 1, 2014 05:22 AM
cheezit
Feb 14, 2010 01:49 PM
Tranoham
Garage & Workshop
Oct 30, 2006 01:10 AM
jobguy
Nov 9, 2003 02:50 PM
