Dash Volt Gauge Question
Old Apr 12, 2014 | 04:59 PM
brianmorgan17's Avatar
brianmorgan17
I just bought my truck and am working through a couple issues.
My dash volt gauge only shows around 10 volts. I put a meter on on each battery and I have 14.8volts.
Where does the volt gauge get its signal? Are these dash gauges prone to be off this much?
Thanks,
Brian
Old Apr 12, 2014 | 05:35 PM
Eddiec1564's Avatar
Eddiec1564
Thanks,
Brian
Yep, they are not the most accurate gauges out there.....
Depending on year of truck, the oil gauge is just a glorified idiot light too! It will read middle of gauge with any oil pressure over 5psi unless you do the oil gauge mod and make it into a real but not accurate gauge.
Old Apr 12, 2014 | 07:10 PM
jroehl's Avatar
jroehl
The voltmeters I've had in my Ford trucks have always been in line with a DVM reading at the battery terminals. But not everyone here has been that lucky--the dashboard voltmeters seem to be a crapshoot.
Jason
Old Apr 12, 2014 | 07:34 PM
tjc transport's Avatar
tjc transport
i ain't rite
what year truck?
i found with my 88-91 trucks if you smack the top of the dash HARD when running the gauge will work properly.
the way it was told to me by the ford service rep was there was a batch of bad gauges, and the dial would stick on some of them when bottomed out.
so to get them working give the top of the dash above the volt meter a good whack after starting the engine.
if it works, bring the truck back and we will replace the gauge.
it worked, but i never took any of them back.
Old Apr 12, 2014 | 09:09 PM
brianmorgan17
I'm sorry I left off that it's a 1989 F350
Brian
Old Apr 12, 2014 | 09:20 PM
joey2fords's Avatar
joey2fords
welcome to the 10 volt club.
i am going to give toms high tech method a try though.
Old Apr 13, 2014 | 10:34 AM
dixie460's Avatar
dixie460
Mine was like that too... I took the needle off and put it back on where it should have been pointing. Now it (mostly) agrees with the digital meter.
Old Apr 14, 2014 | 08:25 PM
brianmorgan17
I hate to say this ....
Tom's the man
Two firm, not hard raps with my left palm, Gauge reads correct.
Thanks.
Brian
SuperDuty93
Sep 30, 2013 08:56 PM
pineconeford
Mar 31, 2013 10:20 AM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 1, 2010 07:57 PM
FARM69
54
Jan 21, 2008 01:24 PM
51truck
Electrical Systems/Wiring
Mar 19, 2004 09:59 PM
