1997 LTD IAT Sensor
Old Apr 19, 2014 | 01:53 AM
Flash635's Avatar
Flash635
I ended up downloading torque pro so I've got the ELM 327 working now.
I cleared the code for the IAT and TPS then disconnected the battery for a few minutes for the new TPS switch.
I then read the codes - none.
And it drives exactly the same.
Old May 4, 2014 | 04:18 AM
Flash635's Avatar
Flash635
If anyone's still listening or cares, I found the problem.
The vacuum line that goes from one side of the bulkhead to the other had about 6 inches missing from it.
I replaced that and repaired a thin vac line going to some vac pot at the front of the engine and now it runs fine.
I would have thought that that much of a vacuum leak would throw a code.
Somehow I ended up with the kind of transfer case that doesn't have the VSS on it so I've still got some work to do.
Old May 4, 2014 | 08:53 PM
shorod's Avatar
shorod
Congrats on finding the vacuum leaks. Hopefully that takes care of your Explorer for awhile.
-Rod
Old May 7, 2014 | 12:53 PM
Flash635's Avatar
Flash635
-Rod
You know what else causes occasional stumbling and missing?
A BLOODY GREAT TEAR IN THE No. 1 spark plug lead.
daughtersbronco
Bronco II
Aug 1, 2010 07:57 PM
erik_bishop
Jan 16, 2008 03:09 PM
Rondigsit
3.0L V6
Apr 19, 2004 01:14 PM
dtong_ck
Aerostar
Dec 16, 2001 09:16 PM
