Alternative fuel- propane
Old Apr 8, 2014 | 09:29 PM
rtreftz's Avatar
rtreftz
My 1954 F100 is a project I bought from a family friend. It has been through a very long restoration and I bought it as a basket case. It had $8000 invested in the engine with a new Holley 600 cfm carb, Sitting off and on for the last 10 years, I got it road worthy a couple weeks ago and drove it. After a 5 mile trip, I had a wheel cylinder give out and carb was over fueling due to debris in needle and seat. I disassembled the carb and found the bowls and plate peeling apart. The bowl also had a hole all the way through it. After research, I found the fuel was causing a caustic situation due to methanol. I have decided to go with propane carb set up. Has anyone tried this? There is no spoilage and the fuel is $2 per gallon. I buy wholesale so, the set up is not much more than a good new carb.
Old Apr 9, 2014 | 07:03 AM
49willard's Avatar
49willard
Check out Holmsey's build UK Hot Rods: News, tech, chat, email group for hot rods, street rods and kustoms.
He is in the UK
Old Apr 9, 2014 | 07:29 AM
big job's Avatar
big job
All I can say I have a friend a local propane co. His propane trucks mainly
391's and 429's all on propane. 500,000 miles absoulutly nothing- pulling
rockers covers off. spark plug still new at a 100,000 oil changes quadruplled.
No sludge clean tail pipes etc. so you be the judge.......
Old Apr 9, 2014 | 09:11 AM
dadgonebroke's Avatar
dadgonebroke
propane
Just like Big Job said. My dad had a propane business and no issues. The propane tank and it's size may be the only issue.
Old Apr 9, 2014 | 11:16 AM
arctic y block's Avatar
arctic y block
I don't see where you have said what engine is in your truck. I am
guessing it's not original. Right? The only thing I know of against
propane power is that it makes less Power. But with a bigger engine
that's over come to a point.
Old Apr 9, 2014 | 09:57 PM
rtreftz's Avatar
rtreftz
Power loss is not a problem. I have more than 1 tire can handle. It is a mildly built 302 roller and 5 speed out of a 1989 GT Mustang. I heard of a 5% power loss. I would say that I have around 300+. I am a Parts Manager at a forklift dealership and buy all lp parts wholesale. I found a mixer (carb) that you use a throttle plate from my dead 600 cfm holley... works for me. I will be using either 44.5 or 33.5 # tanks in the bed. We have plenty for free to me as in most of the parts. I only have to buy the regulator and carb.
Old Jul 20, 2014 | 09:04 PM
thelal's Avatar
thelal
There are several propane "options" for a truck depending on what (newer) technology you want to put in, what budget etc.
Old Jul 20, 2014 | 09:43 PM
aussiecowboy's Avatar
aussiecowboy
Done properly there is no power loss with propane, very common conversion in Australia although less so now as the price of gas is rising quickly.
cb300wsm
Aug 5, 2016 09:26 AM
IsoGrifo
Sep 15, 2007 03:15 PM
mustange70
Jul 23, 2004 12:22 AM
72 Camper Special
May 18, 2004 03:01 PM
Billyboy501
Nov 14, 2002 03:41 PM
