Hope nobody minds a stupid question. I simply cannot get the filter case off. It is a cast part and I am afraid I am going to break it. Part of the bottom has already come off. Thanks, gm.
I had a similar problem before. When I used the impact wrench, my stupid self accidentally went the clockwise way, and even if it was for a sec, damage done. Once it's cross threaded or the O-ring is seized or damaged, tat bell housing ain't coming out. Be careful u don't strip those lines. I ended up stripping tat stupid nut off. It actually broke off.
It would be nice for an explanation. It looks like NTZ Mfg's these for Motorcraft. Every product I find is essentially the same stamped filter. Why would Motorcraft not include the o ring? Is it an item they sell extra for some more profit or is it considered not necessary when changing? I really thought I changed mine out last time I replaced. Maybe not?
Yes sir. Ford sells them separately. It is definitely needed. I have never changed my o-ring ever and I had already been thru about 3 tranny fluid changes.
