1978 - 1996 Big Bronco
while i'm in there..
Old Apr 8, 2014 | 12:15 AM
flysf150's Avatar
flysf150
new to me, 96 eb with 5.8, auto, I think a 3" and 33's. I have a front brake dragging and squeaking. planning to replace, rotor and pads, lines, calipers, bearings, king pins and ball joints. as long as i'm in there..anyone think of any thing else?
Old Apr 8, 2014 | 07:25 AM
Fordman96's Avatar
Fordman96
While you're down there you can check out your all the body mounts, radius arm bushing, tie rods, look for leaks.
You should be able to fit 33s under your truck too without a lift too, it's what I'm running right now, she just rubs a little on full cranked wheel.
Old Apr 8, 2014 | 07:51 AM
flysf150's Avatar
flysf150
I think it came with the lift..it only rubs when in reverse and turning. it has a block between leafs and axel..so I am assuming. it needs new tie rods and bushings too..just another weekend.
Old Apr 8, 2014 | 06:32 PM
Fordman96's Avatar
Fordman96
Since it has a lift, you should try looking into the tie rod end flip. I hear it gives you a better steering radius with the lift. As for the blocks in the rear, you might want to also look into just switching to larger leafs so you can get rid of the blocks.
GuitarJesus
Oct 9, 2014 10:24 PM
quaallen
17
Jan 26, 2011 10:37 PM
Storm
Apr 30, 2007 04:36 PM
98F150CA
Apr 5, 2005 04:03 PM
tgrohman
1966 - 1977 Early Broncos
Apr 9, 2004 09:55 PM
