Sponsored by: Real Truck
Help, transmission discovery
Old Apr 6, 2014 | 01:44 PM
Smitch3806's Avatar
Smitch3806
Just got a 2003 F350 4x4 with 6.0 155k
Crawled under it today and noticed this hole has been cut in tranny case. Why would someone have done this? Will it hurt anything? Should I cover it somehow and if so how? Thanks in advance. I know I'm new here but any insight is appreciated
[IMG][/IMG]
Old Apr 6, 2014 | 01:45 PM
Kdr358's Avatar
Kdr358
looks like they cut it to get to the torque converter bolts. Its safe to say either the motor or transmission have been removed. I would try to cover it with something to keep the crap out of there.
Old Apr 6, 2014 | 04:41 PM
redrivergorge's Avatar
redrivergorge
Why would they do that? I've never pulled a 4r100 but every trans I've pulled had access thru a dust cover. I'd be worried about what else the so called mechanics did to that thing.
Old Apr 6, 2014 | 04:49 PM
MisterCMK's Avatar
MisterCMK
They probably did it to get easier access to the torque converter nuts and to turn the motor over without removing the fan shroud.
Sent from my Telegraph using IB AutoGroup
Old Apr 6, 2014 | 05:42 PM
Bigpipes 35's Avatar
Bigpipes 35
Its a 6.0 so its not a 4r100..
Old Apr 6, 2014 | 06:16 PM
r2millers's Avatar
r2millers
I think I'd reach out the the previous owner for an explanation.
What a hack job!
I too would find something to cover, duct tape if necessary until you can improvise.
Old Apr 6, 2014 | 06:18 PM
MisterCMK's Avatar
MisterCMK
If you want to cover it up some sheet metal or aluminum and a few screws should do it
Old Apr 6, 2014 | 08:30 PM
EXv10's Avatar
EXv10
Probably to turn the motor over, it won't hurt anything. The local cats might see it though.
Old Apr 6, 2014 | 09:15 PM
Forddiesel06's Avatar
Forddiesel06
I to would cover that just like mention . Oh by the way Welcome to the FTE.
Old Apr 7, 2014 | 01:56 AM
projectnitemare's Avatar
projectnitemare
I'm going to guess someone stripped the converter nuts. They did that to get a torch in there to blow them off without cutting into the flex plate. Yeah it looks crappy and is a hack but not huge issue.
Old Apr 7, 2014 | 08:34 AM
Gangly's Avatar
Gangly
The "mechanic" wanted access to the flex plate bolts, simple as that. The tranny has been disconnected from the engine before but thats no biggie. The bell housing primarily acts as a mounting plate/dust cover anyways so get a sheet of aluminum and attach it to the bellhousing to cover that hole if you want to. Either way, it wont affect the workings of the truck. If anything your converter might last longer because it's able to stay cooler now that its getting circulation but I highly doubt it. Ignore it or fix it, either way it doesnt affect the workings of the transmission.
Pikachu
15
Jan 19, 2014 09:48 PM
tshrager
Dec 15, 2011 03:00 PM
GregN
Oct 21, 2009 07:29 AM
brian42
Jun 1, 2008 01:42 PM
Beaned
Aerostar
Nov 18, 2006 12:02 AM
