Fire Ext. Questions
Old Apr 6, 2014 | 09:06 AM
rockittsled's Avatar
rockittsled
Fire Ext. Questions
What is the preferred brand of fire extinguisher and where do you have it mounted? Also, did you use the supplied mount or aftermarket for better security?
Old Apr 6, 2014 | 11:52 AM
410 Highboy's Avatar
410 Highboy
My fire extinguisher is mounted on the inside panel on the passenger side .
Old Apr 7, 2014 | 08:09 PM
rockittsled
bump with 20 characters
Old Apr 7, 2014 | 09:17 PM
ROKRAWL's Avatar
ROKRAWL
Supplied Mount. Above driver head. Between rear glass and headliner.
Old Apr 7, 2014 | 09:33 PM
devino246's Avatar
devino246
No preferred brand, since they all have to meet NFPA standards. Can't go wrong with a 2.5lb rechargeable ABC extinguisher.
Old Apr 8, 2014 | 12:07 AM
rockittsled
I have the remains of a plastic mount on the tranny tunnel up by the firewall that looks like it was attached with sheetmetal screws and eventually kicked loose. Just want something stronger that wont break away in an accident, but still be close enough at hand to grab
Old Apr 8, 2014 | 09:03 PM
grinnergetter's Avatar
grinnergetter
Expensive but nice....although a Ford on fire is more expensive.
SYNERGY MANUFACTURING*::*Body & Exterior*::*Synergy Quick Release Fire Extinguisher Mount
Old Apr 8, 2014 | 09:14 PM
arthurfelter's Avatar
arthurfelter
Mine is also mounted on the inside panel on the passenger side, and it doesn't make much sense to me there. If I were to do it over, I would mount it somewhere more easily accessible.. (not sure where that would be, though...)
Old Apr 8, 2014 | 10:31 PM
rockittsled
True......but even more true
Old Apr 8, 2014 | 10:45 PM
Jklnhyd's Avatar
Jklnhyd
Above your head?! That will kill you in an accident before a fire.
I would just mount it behind the seat.
jimzpsd
May 28, 2018 05:07 PM
onug
2015 - 2020 F150
Jun 26, 2016 11:57 AM
BPofMD
All Things Towing
15
Aug 29, 2011 07:55 PM
Yeti
Oct 24, 2002 02:08 PM
