Sponsored by: Innova
Tweater Location
Old Oct 23, 2002 | 10:46 AM
Yeti's Avatar
Yeti
Tweater Location
Just wondering if there is a "agreed on" location to mount some component tweaters?
I read a post here , where it was recomended to put them on the A pillar, and point towards the windshield?
Old Oct 23, 2002 | 08:29 PM
optikal illushun's Avatar
optikal illushun
Tweater Location
sound has a very distincitive(sp) pattern, bass is non-directional but nething above 60-80hz is dirictional. there a few spots to mount tweeters. one is on the power window/lock panel mounted slightly on an angle. another is in a kick-panel type and since u said component tweeters i take it u have/getting components. there are 2 ways u can go about this, buy a cusom kick from q-logic (look on crutchfield site) or make a custom fiberglass kick-panel. if u want details on making a cutsom kick give me an IM and ill hook u up. the other spot u can mount them is where the wing window and the little curve is (at least on mine, but in that area for urs. u can also mount them with velco on near the top of the door so that its pointing towards u. if i confused u, give me an IM and ill explain it better.
remember sound, espically mids but more the high are dependent on direction to get full affect.
Old Oct 24, 2002 | 10:23 AM
Yeti's Avatar
Yeti
Tweater Location
I ended up putting them on the lower part of the A pillar by the dash.
I originally had them at the top of the A pillar but it just seemed to close to my head and was a little to much, I didn't want them on my door switch panel, because with my truck, if it's raining, it seems that panel gets wet.
Got the subs all in, I have each 10" behind my seat, so It seems you really feel the punch.
I'm sure that someone who really knows what there doing could tweak it a little more but for me and my messed up hearing, it seems pretty dam good!
Thanks for all your help, it is much appreciated!
Old Oct 24, 2002 | 01:50 PM
optikal illushun
Tweater Location
glad to hear ur system is good for UR lissening pleasure.
Old Oct 24, 2002 | 02:08 PM
optikal illushun
Tweater Location
