Bleeding the clutch
Old Apr 6, 2014 | 08:29 AM
spaytons's Avatar
spaytons
Bleeding the clutch
I finally got my 89 150 on the road yesterday.
The clutch feels a little soft and the book I have (chilton) mentions nothing about adjustments or bleeding the line.
Also, where the hydualic line connects to the case, the fitting wiggles.
Is that normal? At first glance I didn't see any way to snug it up.
Old Apr 6, 2014 | 09:38 AM
spaytons's Avatar
spaytons
heres the part that wiggles. (image jacked from another thread)
Old Apr 7, 2014 | 08:57 AM
jas88's Avatar
jas88
Don't worry about the fitting as long as it doesn't leak. It just snaps in there so, yeah, it may wiggle a bit. There should be a bleeder fitting next to where the fitting goes in, tho.
Old Apr 8, 2014 | 06:39 AM
spaytons's Avatar
spaytons
Thanks. Was beginning to think noone would reply
Old Apr 8, 2014 | 09:15 AM
jas88's Avatar
jas88
If you find the bleeder screw, you can just gravity bleed it. Just open it up and let it drip for a while and keep the master full of fluid.
Old Apr 9, 2014 | 07:29 AM
spaytons's Avatar
spaytons
ya, cool. that fluid is as black as a ex-wifes heart
Old Apr 14, 2014 | 02:59 PM
RickTFL's Avatar
RickTFL
Did you find the bleeder? I don't see it on my 91 and I don't what to pull the bell housing to get at it.
Thanks
Old Apr 15, 2014 | 08:29 AM
spaytons's Avatar
spaytons
Thanks
Rick, I've real busy and haven't had time to look into this. You might want to ask Jas88 if he knows where its at.
Old Apr 15, 2014 | 09:21 AM
RickTFL's Avatar
RickTFL
Jas88. I don't see the bleeder on my 91, do I need to pull the bell housing to get at it?
Old Apr 15, 2014 | 04:18 PM
jas88's Avatar
jas88
Your '91 what???
Old Apr 15, 2014 | 08:51 PM
BiGGreen350's Avatar
BiGGreen350
a easier way and cheaper/cleaner is to park the truck nose high on a STEEP hill/ incline.
remove your master cylinder cap, remove the rubber boot insert and replace cap. let it sit for a day and it will gravity bleed itself.
naturally the air wants to come out.
do not drive the truck without the rubber insert though. we have a steep driveway hill at my uncles and we bleed all of ours this way. SUPER EASY!!!!!!
no wasting a bunch of fluid either!!!!
Old Apr 16, 2014 | 07:22 AM
RickTFL's Avatar
RickTFL
Thanks much! Living in Florida, (flat land), that may be a challenge. I have tire ramps but I don't think they will be high enough. I will try though.
Old Apr 16, 2014 | 03:18 PM
jas88's Avatar
jas88
If you have a Mazda 5-speed (M5OD, also called M5R2) then your bleeder is here:
Old Apr 16, 2014 | 03:19 PM
RickTFL's Avatar
RickTFL
I will look tonight and update. THANKS!!
Old Apr 19, 2014 | 09:03 AM
RickTFL's Avatar
RickTFL
That is it.... and my slave is leaking... ugh... so is the best way to do this to drop the transmission completely and change it out? I've never changed a clutch, how much work is that once the transmission is down? Thanks for the picture that helped.
