Gears
Old Apr 5, 2014 | 11:11 AM
FF34's Avatar
FF34
Gears
How do I tell what gears I have on my truck? I see a lot of post where it's mentioned like they have 3:55 or 4:11, what exactly does this mean and what's the difference?
Old Apr 5, 2014 | 09:11 PM
Red454sedgwick's Avatar
Red454sedgwick
look at the axle code on the door frame, if it ends in a 5 you have 4:11, if it ends in a 9 you have 3:55, if there is a letter with it t means you have limited slip. or look at the metal tag on the axle.
3:55 are higher gears they make your rpms about 2000 at 75mph, they get better mileage
4:11 are lower run around 2500 at 75, better for hauling
limited slip means it harder to get stuck.
Old Apr 6, 2014 | 02:40 AM
Ford F834's Avatar
Ford F834
The number itself is the ratio of drive shaft revolutions to 1 axle revolutions... So 4.11 revolutions to 1 axle revolution means it is easier for the engine to do the work but your speed is slower. They are good for heavy hauling where you need the power. 3.55's are more of a free wheeling overdrive gear that keeps your rpm's at a reasonable level for freeway driving and greatly helps mpg. In addition to the door sticker, there should be an aluminum tag under one of the differential cover bolts that identifies the gearing. Counting drive shaft revolutions to one wheel revolution also works, as does the ratio of pinion gear teeth to ring gear teeth...
Old Apr 6, 2014 | 08:36 AM
BruteFord's Avatar
BruteFord
Let me google that for you
Old Apr 6, 2014 | 01:26 PM
FF34's Avatar
FF34
Thanks guys! That helped a lot. Judging by my rpms iv got 4:11 gears, but ill go check out the tags to double check.
Old Apr 7, 2014 | 10:15 PM
speedwrench72's Avatar
speedwrench72
3.73L is what I want for my van.
andres0517
Jan 7, 2013 04:53 PM
nstueve
Jun 30, 2009 08:29 AM
Bino2
25
Apr 5, 2008 10:45 AM
buffaloboy123
Oct 15, 2004 11:34 AM
KillerF250
Sep 19, 2004 02:27 AM
