Trouble code 536 BOO
Old Apr 6, 2014 | 06:42 PM
subford's Avatar
subford
Well you are suppose to put the back end up on jack stands and run it up with the front wheels blocked. Also do not aim the truck at anything important.
Old Apr 7, 2014 | 10:54 AM
Alfred E Newman's Avatar
Alfred E Newman
OK lol my wife will like that a lot better
Old Apr 7, 2014 | 12:53 PM
Krisverde's Avatar
Krisverde
I haven't read through everything. But IIRC if a BOO switch isn't working correctly that can cause issues with the TCC. I believe once the switch is activated it turns off the TCC. Correct me if I am wrong.
Old Apr 7, 2014 | 01:09 PM
subford's Avatar
subford
No you are right, anytime the BOO switch is pushed and the TC is locked it will unlock.
We are also looking at the bouncing speedometer. That is why he wanted to know how to check the VSS train.
Old Apr 8, 2014 | 03:55 PM
Alfred E Newman
OK I finely got to put the metter on the RBAS plug no voltage found. What now
Old Apr 8, 2014 | 03:57 PM
Alfred E Newman
RABS plug I new I could not spell
Old Apr 8, 2014 | 07:23 PM
subford's Avatar
subford
Unplug the PSOM and the RABS module and see if voltage returns.
Old Apr 8, 2014 | 08:53 PM
Alfred E Newman
I don't know what the PSOM is or where. and the RABS.
Old Apr 8, 2014 | 10:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
PSOM: Programmable Speedometer/Odometer Module
https://www.ford-trucks.com/forums/1...s-but-why.html
RABS: Rear Anti Lock brake sensor.this is a multi sensor.it's also the VSS: Vehicle Speed Sensor.it's that sensor in the rear diff.
Old Apr 9, 2014 | 09:01 AM
Alfred E Newman
Thanks for your help. It will be a day or two before I can get to the cluster. I'll solder the pins better while I'm at it. I'll let you know what happens.
noidnar
24
Sep 11, 2010 08:45 PM
Oval_obsessed
Apr 29, 2008 07:09 AM
lattices2
1978 - 1996 Big Bronco
Jan 16, 2007 12:28 PM
goinbig78
Mar 3, 2004 11:03 AM
burley208
Jan 13, 2003 09:50 PM
