1991 Ford f150 new actuator cranks over but wont start
Having trouble with a friends 1991 f150 2wd truck. Had to start the truck by jumping the solenoid. He put a new ignition in it and didnt fix it. Then I put a new ignition switch and still didnt work. So then I seen something about the actuator inside. Used the step by step on FSB.com and got it all in. Went to start it and all it does is crank but not start. He says the lights and gauges arent working the same but they are working. Tried to jump it the old way it started but no go. He says he cant hear the fuel pump turning on. I need some kind of help been messing with it for two days and im stumpped and frustrated.
To start with you just do not just start replacing parts. This very seldom fixs the problem and will cause more problems.
You start by getting a test light and check for power at the push on wire at the starter relay on the fender when the key is turned to start. Do you have power?
Also need more information about the truck.
What size engine do you have in it?
What transmission do you have in it?
on
You say he "put a new ignition in it". What does that mean? When you say you changed the ignition switch, do you mean the lock cylinder (the thing the key goes into)? Or the actual switch down on the steering column near the firewall?
The first thing I would do is shoot a little starting fluid into the throttle body while cranking to see if if fires up. If it does, your problem is no fuel. If not, your problem is no spark.
7.3LSuperDuty
11-02-2007 01:17 PM
86F150-Lariet
30
07-19-2006 01:37 PM
boss3024me
05-07-2001 10:46 PM
