Sponsored by: Auxito
another trailer light thread....
Old Apr 4, 2014 | 11:51 AM
AhoyMatey's Avatar
AhoyMatey
Sorry for another one but trailer light dont work right. If the running lights are on the brakes dont work. If the running lights are off the brake lights work fine. I cant drive at night this is a huge issue for an up and coming transporter. Its not the trailer lights ive eliminated that with my plug checker. Is it the rely? Blown fuse? Or common ford electrical mess up?
Old Apr 4, 2014 | 12:43 PM
Bluegrass 7's Avatar
Bluegrass 7
It sounds very much like a ground issue.
When to much current is drawn, the ground resistance drops to much voltage across the resistance due to the extra current flow of both light circuits..
Your tester won't tell that.
Good luck.
Old Apr 4, 2014 | 05:35 PM
steve(ill)'s Avatar
steve(ill)
yes, ground is bad. If your connected to the ball, it should help ground. Clean the rust a off the ground wire bolt and make sure everything is clean. You can also use a jumper cables to ground the bumper to the trailer hitch as a test.
1999-F150
1997 - 2003 F150
Jul 17, 2017 05:55 PM
BigBlue92
2009 - 2014 F150
Nov 9, 2014 07:10 PM
IslandBlueV10
All Things Towing
Mar 17, 2011 08:33 PM
Thompy
1983 - 2012 Ranger & B-Series
May 21, 2008 07:55 PM
sublimecharger68
All Things Towing
Aug 7, 2002 10:43 AM
