Which DC Power Alternator??
Old 04-03-2014, 05:15 PM
Militant83's Avatar
Militant83
Militant83 is offline
Question Which DC Power Alternator??
I plan on upgrading my alternator but I'm torn between The DC Power 190 HD 6G or the 250 HD6G.
The only electrical items my truck powers outside of the normal loads is a dvd play and I plan to add recon halo head lights, and a FASS fuel system. Any advice on which alternator best suit my needs?
Thanks
Old 04-03-2014, 06:25 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
AT one time i was an alternator minimalist, using a 140 amp unit. The dc power is my 4th after market unit! I would buy the largest alternator you can afford. You may add a winch or power inverter and the extra power of the larger unit would help out.
Old 04-03-2014, 06:31 PM
Militant83's Avatar
Militant83
Have you had any issues with the DC unit? Also do you know how much of a difference is in the HD 6G units compared to the HD XP units of equal amps?
Old 04-03-2014, 07:57 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
The DC Power HD units are based on Delco-Remy alternators with a custom frame.
No 6G internals are used.
Josh
Old 04-03-2014, 08:06 PM
Nice Work Truck's Avatar
Nice Work Truck
Nice Work Truck is offline
I have the 270xp and love it.
Old 04-04-2014, 03:29 AM
Militant83's Avatar
Militant83
For the guys with the 250 amp and above, I'm being told you have to have new charging cables for those units. What cables are you guys using?
Old 04-04-2014, 04:35 AM
Nice Work Truck
I made my own wit 2/0.
Old 04-04-2014, 11:32 AM
firedaniel's Avatar
firedaniel
firedaniel is offline
If your not running anything to speak of then the 190 is more than good. I put a 190 on mine it works just fine.
Old 04-04-2014, 01:49 PM
Militant83's Avatar
Militant83
What did it cost to make your own vs. the premade ones people are selling for $100 or so?
Old 04-04-2014, 05:17 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
If both of them are $100 then i would buy them! It cost about that much, the advantage would be the perfect fit/length. I fused mine with a 300 amp surplus fuse from ax-man...
Old 04-04-2014, 06:23 PM
Militant83's Avatar
Militant83
Ed at FICMrepair.com sells a set for around $110 that is designed just for the 6.0
Old 04-04-2014, 07:26 PM
Nice Work Truck
It ran me about $250 in materials.
But it is high grade marine cable.
Old 04-05-2014, 10:24 AM
FICMrepair.com's Avatar
FICMrepair.com
FICMrepair.com is offline
Former Vendor
Yes indeed! The 1/0 cable kit sold by DC Power directly is too short for our trucks. The cable kit ordered through us comes from them, includes the fuse block with properly sized fuse, and is a perfect fit!
Thanks again for the referral!
Old 04-05-2014, 12:12 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Any DC Alt would be better then STOCK
One of the Best out there of all the brands
IMO we should Also run a Extra cable to Driver Battery too
Maybe Overkill IDK
That And a Desulfater
Old 04-05-2014, 12:26 PM
FICMrepair.com
Former Vendor
Blade35 is correct that any I the DC Power are a huge improvement over stock. For those not running aftermarket accessories that drain power, the key consideration is the length of trips (as longer trips provide the necessary time to recharge the batteries) in concert with how much of the post start up glow plug draw you want to cover to further keep your FICM happy. We sell a ton of the 250HD units since they nearly cover the nut and a ton of the 270XP's since they completely do while even allowing you to run the heated seats without concern.
Quick Reply: Which DC Power Alternator??
