Clutch knocking/banging
Old Apr 3, 2014 | 09:51 AM
shabazz18's Avatar
shabazz18
So for lack of a better term, the clutch on my 1978 3 speed manual sounds like it has a bad rod bearing lol. Very loud knocking, banging sound while running. With foot off the pedal, it more or less goes away, but touch the pedal and its non stop and can be felt through the pedal. Clutch seems to function/release fine, but knocking continues until foot is off the pedal.
Ideas?
Old Apr 3, 2014 | 10:14 AM
bpete's Avatar
bpete
Your throw out bearing is bad. Pull your transmission and replace it.
Old Apr 3, 2014 | 10:56 AM
DutchmanAZ's Avatar
DutchmanAZ
I agree with bpete. If it were me, while I had everything apart, I'd redo the clutch and pressure plate, and perhaps even resurface the flywheel while I'm in there.
Old Apr 3, 2014 | 12:58 PM
paredneck33's Avatar
paredneck33
Yep it sounds like a bad throw out bearing. Time for a clutch job or live with it till she blows. Been there done that. Can give you one helluva ride. And be very costly to repair/replace. I don't recommend that choice.
Old Apr 3, 2014 | 01:48 PM
FordFanboy's Avatar
FordFanboy
What I would NOT recommend is making a pass at the track like that. Guess how I know...
Old Apr 3, 2014 | 11:49 PM
shabazz18's Avatar
shabazz18
Was definitely the throw out/release bearing. Pressure plate also had broken teeth and the flywheel was chewed up pretty good too so I replaced everything today. I left the pilot bearing since it felt fine and i didn't have a way to pull it out at the time. I'm not to worried about it.
tyrantsparky
Feb 4, 2015 01:41 PM
Morris98
Dec 2, 2007 07:49 PM
Unimog005
Oct 19, 2007 08:00 AM
knocturnal
13
Oct 16, 2002 07:07 PM
jon69f250
Apr 5, 2002 10:00 PM
