which shocks
Old Apr 3, 2014 | 08:13 AM
Jarryd's Avatar
Jarryd
which shocks
Still rocking my 2 wheel drive system but I can reuse whatever I get when I finally find a donor truck for my 4x4 conversion.
I have a 2" lift and the truck bounces all over the place every time I hit a little bump in the road. I'm looking for a comfortable smooth ride. I've seen Rancho and superlift and kyb. Not sure what to get but I will get the longer ones while I'm upgrading.
Old Apr 3, 2014 | 10:27 AM
White Max's Avatar
White Max
I'd recommend a "name-brand" monotube shock. I personally like the KYB Monomax shocks on these trucks at that price point, but there are many, many choices when it comes to shocks for these trucks.
Old Apr 3, 2014 | 11:31 AM
Jarryd's Avatar
Jarryd
I was planning on going name brand, just didn't know what would give the best ride with my options of those kybs or what I mentioned above.
Old Apr 3, 2014 | 12:16 PM
White Max's Avatar
White Max
Take a look at the specs. The offerings from both Rancho and Superlift are going to be twin-tube design. Bilstein, KYB, SkyJacker, Edelbrock, Monroe, etc. offer monotube shocks for these trucks.
Old Apr 3, 2014 | 03:42 PM
Jarryd's Avatar
Jarryd
So I see why the monotube is better now, but I don't know what to pick as far as what is going to give the smoothest ride and make my truck more comfortable.
Old Apr 4, 2014 | 11:26 AM
White Max's Avatar
White Max
That will be a matter of personal preference and budget. Keep in mind that shocks will only do so much in terms of ride characteristics. Springs, anti-sway bars, and tires all play a important role here.
In order to determine which shocks will be "softer" or "firmer", you'll need to obtain the valving data for the shocks you're considering.
Old Apr 4, 2014 | 11:28 AM
Jarryd's Avatar
Jarryd
I'm running stock springs and no sway bars. I have a rear sway bar laying around but don't want to use it without a front bar.
Old Apr 4, 2014 | 11:38 AM
Encho's Avatar
Encho
The Southernmost Mod
Go with Bilstein, they make the best shocks for these trucks, unless you decide to go full wallet, then you might want to look what does Fox have to offer, a little tip, the longer the shock, the softer the ride.
Old Apr 5, 2014 | 07:00 AM
Jarryd's Avatar
Jarryd
Thanks. Looks like I'll be checking out the bilsteins.
Old Apr 5, 2014 | 08:13 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
kidkyle21
Jun 1, 2012 10:13 PM
92nite351
1997 - 2003 F150
Jan 8, 2012 12:11 PM
Big O 4085
2004 - 2008 F150
Oct 28, 2010 07:11 PM
94' Ford
Jul 12, 2004 05:49 PM
