Electrical
Old Apr 2, 2014 | 06:35 PM
Mezman's Avatar
Mezman
Trailering
Electrical
85 - 6.9 F250. 4x4. Alternator went out so I bought a new one now its over charging. Probably what caused the old one to burn out, any ideas?
Old Apr 2, 2014 | 08:14 PM
Macrobb's Avatar
Macrobb
First, overcharging? What voltage?
Second, these alternators have an external regulator. It's about a 3" square box, 1" tall with a 4-wire connector coming out of it on the passenger side inside fender.
Either it's failing, or you've got grounding issues.
Whether you replace it or not, I suggest running a nice ground lead from the engine block to the casing of that regulator(or whatever it's bolted to).
Old Apr 4, 2014 | 08:27 AM
Perk85F250's Avatar
Perk85F250
An over charging alternator can cause the acid level to drop in your batteries. You may want to check the fluid level just to be safe. I hope they didn't get fried by your old alternator...
Old Apr 4, 2014 | 10:21 PM
genscripter's Avatar
genscripter
Mezman, you need to be a bit more descriptive, both in your titles and the content of your threads.
Seriously.... "electrical" ?
also, what's your vehicle? what year? I'd love to tell you what I think your problem is (the VR), but if you have a newer IDI, then you probalby have an internal regulator.
brian42
20
Dec 14, 2016 04:44 PM
fordtough81
Aug 1, 2015 10:55 PM
maximumd93
Mar 11, 2013 09:52 AM
oldblue89
Feb 8, 2011 08:12 PM
rupejosh
Aug 7, 2009 10:50 PM
