351W: Which fuel pump???
Old Apr 1, 2014 | 06:10 PM
hdgapeach's Avatar
hdgapeach
Evening folks. I'm going to replace my fuel pump........as soon as I figure out which one I should get .
I have a '77 F150 4X4 that has a transplanted 351W in it. The Windsor block was in there when I purchased the truck thirteen years ago. Anywho, I'm going through the whole fuel system from tank to carb and have made it to the fuel pump. Checked online at JBG and there are two listed for the same Windsor. I looked at the 80's models figuring that'd be a good place to start for Windsor stuff.
One pump is listed for '80-'87 with a GVW less than 8,500 lbs. The other is for '85-'87 with GVW more than 8,500 lbs. I know my little short bed half ton is under the 8,500 lb. mark, but was wondering what the difference in the pumps are??? I ain't gotta clue what the engine actually came out of.
I'm installing an Edelbrock dual plane intake with 1406 carb, a new Edelbrock "RV" style cam and headers. With those installed, would I benefit from the higher GVW pump?
Probably a dumb question but I'm clueless as to what the difference between the two pumps is. Same price, too. Part numbers are 30235 and 30235A.
I appreciate whatever insight y'all can provide.
Old Apr 5, 2014 | 01:10 AM
LxMan1's Avatar
LxMan1
I think the difference may be a 3rd line that returns to the tank. I am not sure. The stock pump for a 77 T-bird/LTD 351W should work just fine. No need for a high performance pump unless you just want one.
Old Apr 5, 2014 | 12:37 PM
hdgapeach's Avatar
hdgapeach
Appreciate it LxMan1. That's what I ended up doing, getting one for whatever car was close.
I forgot to mention in the original post that the stock intake is on the engine and it's a 4V. My initial worry was that there was a different gph flow for the higher cfm carb when compared to a 2V. I dismissed that thought pretty quick and just went with the same as you suggested. Thanks.
Rusty_S
Aug 20, 2018 03:30 AM
DGMFORD
Dec 15, 2011 12:19 PM
lil_heavy
Feb 4, 2011 09:51 AM
bonechief
Jun 10, 2004 07:45 AM
daveengelson
Jun 2, 2004 11:38 PM
