86 bronco fail :(
Old Apr 8, 2014 | 11:58 AM
Broncogirl86's Avatar
Broncogirl86
86 bronco fail :(
I had my truck 10 years and never had any problems with it. This year was the first time I had a 'no start issue' which I ended up giving a full tune up, new ignition module, both new fuel pumps... The issue now is only sometimes.... Well it failed smog this year first time ever and I am wondering is it possible my EGR valve is causing my issues? Suggestions?
Old Apr 8, 2014 | 03:43 PM
85e150's Avatar
85e150
Post the results of your smog test, along with the passing number.
If possible, post the results of the prior two tests.
What did you fail on?
Old Apr 8, 2014 | 05:26 PM
Broncogirl86
Failed NOx part at 15 mph the max here in CA is 739 ppm and I tested at 1062 at 25 mph the max is 743 I tested ok at 736... But still pretty high - before testing I always tune up and I have all new plugs wires rotor etc.... But I was wondering where I should repair to pass? Also my cold no start issue to fix that.
Old Apr 9, 2014 | 12:01 AM
85e150's Avatar
85e150
EGR would be a suspect with high Nox, and no other issues.
w6pea
17
Apr 14, 2013 12:00 AM
BigJared
May 30, 2011 11:35 PM
steve mohler
Feb 10, 2005 03:22 PM
allen lyons
Aug 20, 2003 01:26 PM
