Sponsored by: Innova
Factory SD tweeter question
Old Apr 1, 2014 | 04:35 PM
Iggy2867's Avatar
Iggy2867
I am installing the factory premium A pillar tweeters in my 2012 F-350 XLT Reg cab. My question is getting through the factory harness that goes from the door to the inner body panel. First, does anyone have/know of a diagram that lists which plugs are for the tweeters(in the factory plug), or second, if I can't find those wires, suggestions on how to cross the gap. Thanks in advance
Old Apr 1, 2014 | 05:47 PM
madsonp's Avatar
madsonp
The problem with going with the stock tweeters if your vehicle didn't come with them, is that a vehicle with these stock have a crossover mounted on the main speakers that the tweeters connect to. I replaced the main speakers in mine to better Pioneer speakers but kept the stock tweeters, when I did this I had to remove the crossover from the stock speakers so I had those to keep running the tweeters.
Old Apr 1, 2014 | 05:56 PM
Iggy2867's Avatar
Iggy2867
I assume you mean the circuit board that is mounted in the plastic. I was thinking that I would have to eliminate that. My problem is either finding the stock wires in the harness, or getting across some other way
Old Apr 1, 2014 | 05:59 PM
Iggy2867's Avatar
Iggy2867
Sorry, I read that wrong, I upgraded my door speakers, and have crossovers, I just need to get there
jimson
Feb 5, 2019 05:42 PM
Genenj89
Oct 28, 2018 03:22 PM
Fordman96
1978 - 1996 Big Bronco
Apr 6, 2012 11:53 AM
TXoutlaw68
Apr 27, 2009 03:40 PM
WildThing327
2004 - 2008 F150
Dec 18, 2004 11:36 PM
