Timken axle
Old Nov 8, 2018 | 02:24 PM
nsboyd1210's Avatar
nsboyd1210
Here is the Thornton NoSpin parts list. It is interesting that a number of different model NoSpins have the same assembly numbers. Attached is the list. This particular manual has no publish date but in the half ton trucks section it mentions applications through 1945 so the publish date is at least that. I believe the 10G1 part number listed will fit my 1950 F5 truck with a Timken single speed axle model number 53566. Based on the list it appears that not only model 10G1 but also models 70G2, 90G1, 110G1, and 130G1 are interchangeable due to having the same assembly number. 40G2 may fit as well, as it has the same assembly number. However, it apparently has a different spring retainer as it has a different part number from the others that have the same assembly number. If anyone has any info on the whereabouts of one of these NoSpins for sale I would be interested.
Nelson
File Type: pdf
Old Nov 8, 2018 | 02:47 PM
nsboyd1210's Avatar
nsboyd1210
Here is the Thornton information for Ford 1/2 ton trucks.
File Type: pdf
nikates
Mar 17, 2011 09:57 AM
FchasE
Mar 15, 2011 07:13 AM
64 hi-boy
Feb 8, 2010 07:59 AM
picklebill
Jun 4, 2003 11:19 PM
wolverineflight31
Dec 8, 2002 04:14 PM
