Yukon vs. Ford Ring/Pinion
Old Mar 31, 2014 | 11:34 AM
Jesser02EX's Avatar
Jesser02EX
I'm planning to have my rear diff rebuilt with a Detroit TruTrac and I'll do a complete rebuild at the same time.
How do Yukon grears stack up? The factory Ford parts have held up for 230K miles. I don't have any issues with them, but for the price I can move to Yukon gears. Are they better?
What is the opinion on aftermarket parts vs. factory parts for such a job as the rear diff rebuild?
Old Apr 1, 2014 | 07:10 AM
projectnitemare's Avatar
projectnitemare
Aftermarket usually costs less and normally fixed factory flaws. Yukon is a great set of gears. Aftermarket gears are easier to set up if you have a bare housing being the pinion depth is scribed on the gear, doesn't matter so much if you have a complete axle. Aftermarket gearsets will normally provide a stiffer crush sleave so be aware you aren't going to compress it with the pinion nut to achieve preload. Normally you will have to start compressing it in a press. They do this to keep it being crushed more during hard gear loads. Don't be afraid of aftermarket gears as long as a they are a quality brand, yukon, nitro, G2 are just a few.
Old Apr 1, 2014 | 08:31 AM
Jesser02EX's Avatar
Jesser02EX
Thank you very much! Since I'm doing a rebuild with a Detroit TruTac diff, I wanted to replace the gears too. Seeing as Ford can be expensive, I wanted opinions on the quality and durability of the aftermarket options.
Seems they will be a good replacement option.
annaleigh
20
Apr 19, 2018 06:53 AM
superrangerman2002
Mar 22, 2013 10:22 AM
JOHN2001
35
Apr 29, 2012 12:09 AM
Sooper-Doodie
Jan 13, 2009 08:30 PM
ETB1
May 28, 2001 01:10 PM
