Help with an ignition problem
Old Apr 9, 2013 | 06:44 PM
rolando4812's Avatar
rolando4812
I just replaced the ignition switch in our 1971 truck. The truck doesn't crank nor click when i turn the key. although the engine cranks when i bump the solenoid. Can you guys throw me some ideas to help me narrow down my problem.
Old Apr 9, 2013 | 09:45 PM
rustywheel68's Avatar
rustywheel68
if you've replaced the switch already, it sounds like the switch may not be getting power. check your wiring from the battery, across the front, down the driver side of the engine compartment, and through the firewall.
Old Apr 10, 2013 | 02:53 PM
Freightrain's Avatar
Freightrain
Welcome to the forums.
Automatic? How's the neutral safety switch? Try holding the shift lever UP higher and see if it works. Typically they get outta whack and need adjusted. It's on the bottom of the column(under dash).
Old Apr 10, 2013 | 03:33 PM
JEFFFAFA's Avatar
JEFFFAFA
Did you replace the switch with one that came with a wiring pigtail? If so, double check the wiring.
Old Apr 11, 2013 | 03:01 PM
Gembone's Avatar
Gembone
also make sure you have all the proper wires on the starter solenoid.
Someone had a wire off on mine when I got it.
Made it so the ignition switch only had power when the truck was running.
I was having to crank it by arching the solenoid until I found and fixed the issue.
ved0303
Jul 11, 2014 04:51 PM
petty437
Jan 4, 2007 05:36 PM
shrapnell
Electrical Systems/Wiring
Mar 13, 2006 09:29 AM
Ford_Six
Jul 24, 2005 09:22 AM
dada
Aug 10, 2003 08:08 PM
