Sponsored by: Auxito
99 F150 Brake Problem
Old Mar 30, 2014 | 08:49 PM
John Markl's Avatar
John Markl
I have a 99 F150, Regular cab, long bed, with a weird brake problem.
With the engine off, the pedal goes firm about 3 inches. But when you start it, the pedal goes to the floor.
I've replaced the master cylinder, and bled the heck out of the 4 wheel cylinders. No soap. The pedal goes nearly to the floor, and does not "pump up".....but does stop the truck.
The ABS light is "on".
Any ideas? I'm stumped.
Old Mar 30, 2014 | 10:32 PM
RebColonel's Avatar
RebColonel
It takes special equipment to bleed the ABS. That Is probably why the ABS light is on. If your truck has rear brake shoes they made need adjusting. I've gone over this before with others. Rethink how ABS works, without the engine running you will have a high brake with the vacuum bled off. When it's running and your sitting still the sensors pick up the wheels aren't turning and the ABS will bypass fluid and you will have a low soft pedal. It is the nature of the beast.
Old May 13, 2014 | 09:55 AM
FurdTurgeson's Avatar
FurdTurgeson
What if you have the same problem but the ABS light is not on? No lights are on, in fact.
So when you're driving and hit the brakes, it is firm for a second or two then goes mushy to the floor? The truck still stops, but it sure gives me an uneasy feeling.
Old May 15, 2014 | 08:01 PM
96f150's Avatar
96f150
..Furd...Your abs module is bad then$$$$...Do a search of "sinking brake pedal" on ford trucks... I have been having the same issue for almost a year now.....I just havent bought a new abs module yet.
Dave042
1997 - 2003 F150
Jan 16, 2016 11:04 PM
windstar99
1997 - 2003 F150
Aug 5, 2008 11:42 PM
billclou
Modular V10 (6.8l)
Jul 17, 2008 11:15 PM
gfreek
1997 - 2003 F150
Mar 25, 2006 06:56 PM
travelall
Nov 12, 2005 03:40 PM
