ABS Problem
Old Nov 12, 2005 | 12:15 PM
travelall's Avatar
travelall
ABS Problem
I have a 91 Explorer sport with a ABS problem. I have replaced the Master Cylinder, Power Brake Booster , Bled the system and the pedal still fades and triggers the abs light and the brake light at the same time. It seems the pedal holds for a little bit until you give it more pressure and then fades to the floor when the car is started. Seems fine when the car is off. I'm stumped....Pads seem O.K. Cant see any leaks externally. Any help would be appreciated....
Old Nov 12, 2005 | 03:40 PM
marragtop's Avatar
marragtop
Have you cleaned or replaced the ABS sensor in the axel? I think that could trigger the light, not sure if it would make the pedal fade. Do a search on the forum, you should find something. Also, how about the vacuum line going to the booster?
