I have a 1985 f250 manual 300l6.
I'm rebuilding the feedback carbed motor and putting a 4brl on it.
I will have to get rid of the feedback electronics.
I'm looking at a dui dizzy with built in icm and coil.
So it only needs a start wire and kill wire. How would I wire this up to my ignition system, meaning key switch.
And would I have to get a new harness? Or could I just wire a flip switch to start the motor and leave the harness be? I have real gauges so I'm not worried about anything but Speedo and fuel and odometer.
Thank you
I don't think your getting what I'm saying.
The distributor I'm getting has the coil and icm built into. I only need a start wire and spark plugs and spark plug wires and my ignition setup complete.
How can I integrate that into my tfi wiring harness.
Okay, is there a spot on the harness that has a plug that I can remove most the wiring? I'd like to clean up the bay since I'm not going to need all the wires and vacuum lines anymore.
Look for a blue/white or white/blue wire going to the old coil. You can get a testlight and put it on this wire to make sure it works the way it should. Key in start and run, testlight on, key in off, testlight off.
