2002 injector problem
Old Mar 29, 2014 | 06:33 PM
Jon Bradshaw's Avatar
Jon Bradshaw
having a low voltage on injector one, changed injector still have it . changed the value cover and the plug in to it checked the harness and checks ok . can anybody tell pins and voltage to check out my idm
thanks jon
Old Mar 29, 2014 | 06:46 PM
Pikachu's Avatar
Pikachu
What do you mean you had low voltage on an injector? How did you come to that conclusion?
Old Mar 29, 2014 | 06:55 PM
milehi_350's Avatar
milehi_350
Here is a good link on IDM diagnostics.
» TB 103: 1994-03 Ford 7.3L IDM Replacement & Diagnostics
Old Mar 29, 2014 | 06:56 PM
Jon Bradshaw
truck wont start did k test and buzz test got error code 261 said low voltage injector 1
Old Mar 29, 2014 | 07:14 PM
Pikachu's Avatar
Pikachu
Here's the pinout for the IDM connector.
https://www.ford-trucks.com/forums/1...l#post14172980
Check the resistance from the commons (pins 23 & 24) to the corresponding injectors. They should all read in the neighborhood of 3.0 - 3.5 ohms. This will verify the complete path between the IDM and each injector.
Mike Bartlett
Jul 26, 2019 03:15 PM
invintive
Jan 28, 2017 10:35 PM
Chester_field
6.4L Power Stroke Diesel
13
Oct 5, 2012 03:44 PM
Aki_A
Mar 22, 2011 05:33 AM
Ratkat
Aug 29, 2008 05:36 AM
