I have a 2003 f350 6.0. Removed a broken stud from the passenger side exhaust manifold and there is antifreeze is leaking through the hole. Should I be worried? It's the top stud farthest to the rear.
I wouldn't buy two heads if only one was needed. I'd even try what fordman suggested and see how long that will last. You could use Permatex gray and possibly seal it for a long time.
