6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Up-pipe/turbo replacement
Old Mar 29, 2014 | 05:20 PM
Demian's Avatar
Demian
So a few weeks ago my truck shut down on me on the highway. Turned out to be a sensor. But the dealer informed me that my up-pipe and high side turbo are in need of replacing. I knew I had an exhaust leak, and now I can see the soot right above the turbo on the hood, as well as the flexible part of the pipe. They want almost $5K to pull the cab and replace.
I haven't had time to get another quote, as I can't afford anything near that right now anyway. But I'm wondering 2 things. First, if I jack up the cab 8", can I replace these myself? Or, even better, if I get a tuner to turn the DPF and EGR off, won't this stop the exhaust from even coming through this pipe? That would give me 1 1/2 years to either pony up for the repair to pass emmissions, or move away from this city, which has been a thought anyway. And it would be a really good reason for the wife to ok the tuner.
Thoughts?
Old Mar 29, 2014 | 07:28 PM
senix's Avatar
senix
Why do you need a high pressure turbo? What is the code or what is wrong with it.
Misaligned up pipes or the flex joint issue does happen.
You can do the turbo cab on btw.
Old Mar 29, 2014 | 08:52 PM
Demian's Avatar
Demian
There has been a celophane flapping sounding whistle since I bought the truck last November. My BIL looked at it, and thought it was an exhaust manifold. But the exhaust smell is very strong in the cab at startup, and almost unbearable during low speed regen, which it has been doing every 100 miles or less lately. It was around 200 miles until I went on a cross country trip for Christmas.
The flexible joint on the drivers side is sooty, as well as the joint that connects the turbo to the turbo cooler(?) closest to the master cylinder. The codes they found were P200E Catalyst over Tem Bank 1, and P242E EG sensor fault bank 1. They fixed the sensor, and said the leak is coming from the high side turbo charge and egr to turbo pipe, causing frequent regen, clogging of dpf, loss of power and exhaust smell.
Thanks for your time,
Matt
Old Mar 30, 2014 | 06:38 AM
senix's Avatar
senix
yeah you got some major issues. Any way you can take it back to where you bought it and have them fix it since it was that way when you bought it?
Old Mar 30, 2014 | 09:11 AM
Demian's Avatar
Demian
Unfortunately it was bought as is, no warranty. It does have 240,000, so I did expect some issues, just not this major right out of the gate.
Old Mar 30, 2014 | 04:55 PM
DrtTrkr's Avatar
DrtTrkr
I am dealing with Turbo issue as well. I found outIF EGR is operating properly you can delete EGR without installing a kit and DPF delete by changing pipe (gearbox.com). The problem I found with that is the coolant can still run through your EGR coolers etc. If there is any issue with them, PROBLEM. Easiest to get a EGR/DPF delete kit and install. The UP pipe is definitely a pain. If you are just replacing the Turbo without doing the EGR delete, it is not fun, but can do. There is a thread in here that helped me considerably. Don't forget that once the EGR/DPF is done, you now have a farm or race truck. I also found a EGR delete kit by sinister, and you don't have to remove the UP pipe. It caps after second EGR cooler as it enters the UP pipe. This was all new to me at first, but this forum and powerstrokehelp.com was helpful. There are some you tube videos that are very informative.
Old Mar 30, 2014 | 05:01 PM
DrtTrkr's Avatar
DrtTrkr
BTW. Don't feel bad. I had mine for 4 months now and spent more fixing than have made payments. It had 170,000 miles. First diesel has not been a joy. Truck is beautiful though. Expensive yard ornament.
Old May 12, 2014 | 06:52 PM
Demian's Avatar
Demian
Just an update: Hauling a big load last Monday into the mountain zoo, the firewall insulation right above the leaks caught fire. Luckily I got it out before it did any damage, other than the insulation. So took the truck to a reputable diesel mechanic in town that changed the DOC and both upipes for just over $2300.
Man does this thing have some power now! I don't know if my economy will go up, but it seems the DPF cleaning cycle frequency is a LITTLE less.
Thanks for all the help.
jonesboys310
Sep 9, 2013 10:50 PM
AKSnowbear
May 12, 2013 11:10 PM
Culvert
Aug 28, 2010 04:04 PM
rhino3
Aug 28, 2008 08:33 AM
jboard
15
Oct 20, 2005 09:47 PM
